05 530i Sport wheel question (help please)
Hey 5ers,
I am hoping someone can shed some light on a problem I?m having. I like I previously stated I have a 2005 530i Sport, and I CANNOT remove any of my (4) 18" 124 wheels with Dunlop run flats. Yes, let me clarify, I cannot take the wheels off the car. (I'm sort of embarrassed having to post for this issue) This is what I've done: E brake, then I loosened the 5 lugs, jacked up the car, and unscrewed the 5 bolts from the wheel and hub. At this moment, I expected the wheel to come free, and I would be able to install my new set of wheels. BUT... this is not the case. The wheel is still solidly attached to the hub.
Question: Did I miss a step, is there secondary locking system for the run flats/124 in addition to the (5) lug screws?
Possibly the wheel is stuck to the hub? Any suggestion to separating the wheel from the hub? What did I miss?
Thanks for looking
Thanks for looking
My Ride: G30 M550i
Model Year: 2018
The wheel is stuck on the hub -- it's fairly normal for this to happen.
Read the following for some ideas:
http://forums.e60.net/index.php?showtopic=36158
yes the wheel is stuck to the hub as it were.
there is nothingt else holding the wheel on, just knock the wheel off, with a hammer, be careful not to hit to hard as it may damage the wheels, but yes this is a common thing, have these wheels been on the car for a long time?
thanks for the replies! I will give it a try when I get back intown. I didn't want to break anything so I didn't put a lot of force into it. I'll update the post when I put my new wheels on.
bestofthebest
03-30-2015 08:12 PM
