Xenon problems
The car is a E60 535d M-Sport 07/06 with adaptive headlights. I have iDrive messages: dipped beam right failure and cornering lights failure. So far I have swapped bulbs, no effect...swapped ballast, no effect. The right xenon stays dark. However I can turn the xenon on with INPA! Strange right? Any clues guys?
Regards,
Joonas
Regards,
Joonas
My Ride: 08 528i TiAg Premium/Cold Weather Pkg, 20% Tint, Technic Harness, JL Audio 12W7, JL HD 750/1 and LOTS of lighting mods!!!!!
Regards,
Joonas
Regards,
Joonas
I have the exact same problem with my car in the same side, I have already swap the entire headlight unit, and the problem seems to be that the passenger side wires for the low beam and the cornering lights are not reciving current, because the headlight works well when I plugg in to the drivers side. ( the angel eyes and the high beams are working just fine),
the fuses are fine also, culd you fix your car INDE? do you have any suggestions?
kurtb23
Apr 22, 2015 04:30 PM
550iwa
Mar 27, 2015 06:45 AM
