WTH Where in the hell are my Subwoofers?
Old Sep 5, 2011 | 05:36 PM
mokk76's Avatar
My Ride: BMW 550i
Model Year: 2011
lol, I guess I deserve that. Yes I have checked the bass setting, it is all the way up and I have it set to Theatre Setting. I also used the INPALOAD app to test the sound and it is dead silent when testing the subwoofers.
Originally Posted by jaycal3
There is a bass setting in your idrive... I would assume you checked that already, but then again you were looking on the underside of your seats for the subs
Old Sep 6, 2011 | 10:10 AM
porsche911targa's Avatar
Sounds like you may be looking "under the seats" literally... they are on the floor as healthservices has indicated. The only way you would have an empty cavity there is if the PO took them out for some reason since the Logic7 system has them.
The non Logic7 systems also have them. They have one less subwoofer that the L7. Not sure where the third subwoofer would be with the L7.
I hate to say it, but there could be a problem with your amp/tuner.
Old Sep 6, 2011 | 11:41 AM
mokk76's Avatar
My Ride: BMW 550i
Model Year: 2011
Thanks porsche911targa, I think i'm just going to pop open the sub enclosures and test to make sure the subs are actuallly still good. Thanks.
Old Sep 6, 2011 | 06:36 PM
mokk76's Avatar
My Ride: BMW 550i
Model Year: 2011
OK, I can eliminate a blown speaker or incorrect EQ settings. I removed one of the subs and connected it to a different sound source and it works perfectly. I looked at the amplifier connections and everything is intact. Is there is a different connection for the subs? Could the amp be faulty affecting only the subwoofer output. Any help would be appreciated........
Old Sep 6, 2011 | 09:15 PM
NoName545i's Avatar
My Ride: 2004 BMW 545i Sport Package, Titanium Gray II Metallic, Wheel Style 124
these subs are not those earth shaking subs
Old Sep 6, 2011 | 09:59 PM
v_therussian's Avatar
Amp could be faulty affecting only the subs, but it's more likely a wiring issue. I'd try to eliminate that before looking into replacing/fixing the amp. Try to go from cheapest to more expensive while eliminating - that'll save you a few
Old Sep 7, 2011 | 08:21 AM
I would agree with the wiring if it only happened to one sub, but what atre the odds that all three subs are wired incorrectly? The OP stated that the wiring looks good at the source. Maybe he could ohm them out for continuity to the correct location and then embrace himself for a new amp, if the wiring checks out.
Old Sep 7, 2011 | 09:55 AM
mokk76's Avatar
My Ride: BMW 550i
Model Year: 2011
Thanks guys, but what is there to check for in a connection, where do I even begin to look for a wiring problem? The 2 connections to the amp look secure and intact. When I take the smaller connection out, I see a small red small. Not sure what else to look for.
Old Sep 7, 2011 | 12:13 PM
Shlooky's Avatar
My Ride: 545i
I believe there is a separate amp for the subs. Check to see if it's functioning first before you mess with the wiring.
Logic 7 only has two subs
Old Sep 7, 2011 | 01:36 PM
mokk76's Avatar
My Ride: BMW 550i
Model Year: 2011
Really? Does anyone know where the second amplifier is located?
