Windshield seal cracking off
My Ride: 04 525i, 04 Dinan M3
I had to replace the back of my windshield since it was cracking a while back. Now the front is cracking from all this 110 degree heat and the last time I washed it a chunk of it came off. How hard is it to replace this, do I need to have the windshield removed completely to get it fixed?, its mostly the top part, the sides are fine, I'll try to take a pic later.
if your car is still under the factory warranty, they will take care of it. I have an appt today to have it done on my 08 535 for the front and back. And no they no not have to take out the window. Try doing a google search, found several threads on this and says it's an easy DYI job
It should be easier then replacing the rear. I believe there is a adhesive on it, but it should tear off without too much issues. Mine got replaced when the windshield got changed and the seal seemed easy to get off.
My Ride: '04 545i, sport pkg, premium sound, sprint booster,
Recently had my windshield replaced with OEM product by Safelite. The top rubber molding was replaced but the bottom was not. According to the tech, the top part came with the windshield from the dealer but not the bottom. Thought it was strange.
As for weird noises, I'm getting a odd noise somewhere near the top. Finally figured it out, it only happens when sunroof in the lift up position. One of the flap raises up and hit against the glass of the roof. Will have to take a look at it this coming weekend assuming is loose.
Just got back from the dealership to have mine done, looks so much better!!
The dealership called a glass company to do it, so I would call the local dealership to see who they use, or check around and might save some money and a headache going straight to an auto glass company.
