What kind a E60 550 rear differential?
My Ride: 07' BMW 550i
I have a sport package so I was thinking if the rear differential on 550 is limited slip or it's just normal one. I have radiator on rear side of the differential.
I was looking to replace fluid there so if it limited slip I wanted to use this :BMW SAF-XJ + FM Booster, yes expensive but that sh.. is only working, at least I know since I had E46 M3.
Thanks
Thanks
My Ride: Black/BlacK
Thanks
Thanks
It should be an open/normal diff. Afaik the only e60 with limited slip diff stock was the M5.
My Ride: BMW E60/5-2007 550i
MINI Cooper Clubman S 11-2007
Renault R4 1986
I think they dont need mechanic limited slip differential.
They have all the elektronic version.
Alsonthey took the brake to stop several wheel
When they need.
Could be the radiqtor to cool the differential oil?
Greeds thomas
When they need.
Greeds thomas
I dont know if it is the still old fashion way to tell if it is limited is to jack up both rear and spin the tires. If spin one side and the other side spins the same direction , then it is limited. If spin opposite then its not. Atleast this is how we did it back in the days with our 240sx's with the VLSD's.
My Ride: Titanium Silver 2008 550i 6MT. Matte black grille and numbers. Carbon roundels. Eibach springs and sway bars. Bilstein struts. UUC SSK. Smoked LED side markers.
Has anyone tried swapping the M5 diff into a 550i?
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic,
Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release,
Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
interested in a lsd im sure there must be ways to use other internals from maybe a e39 or e46
