What gas do you use?
#81
Originally Posted by 2006 BMW 530xi Manual, pg. 195
Fuel specifications
Do not use leaded gasoline, otherwise
permanent damage to the catalytic converter
will result.<
Required fuel
Super Premium Gasoline/AKI 91
This gasoline is highly recommended.
However, you may also use gasoline with less
AKI. The minimum AKI Rating is 87.
If you use gasoline with this minimum AKI Rating,
the engine may produce knocking sounds
when starting at high outside temperatures.
This has no affect on the engine life.
Use high-quality brands
Field experience has indicated significant differences
in fuel quality: volatility, composition,
additives, etc., among gasolines offered for sale
in the United States and Canada. Fuels containing
up to and including 10% ethanol or other
oxygenates with up to 2.8% oxygen by weight,
that is, 15% MTBE or 3% methanol plus an
equivalent amount of co-solvent, will not void
the applicable warranties with respect to
defects in materials or workmanship.
The use of poor-quality fuels may result in
drivability, starting and stalling problems
especially under certain environmental conditions
such as high ambient temperature and
high altitude.
Should you encounter drivability problems
which you suspect could be related to the fuel
you are using, we recommend that you respond
by switching to a recognized high-quality brand
such as gasoline that is advertised as Top Tier
Detergent Gasoline.
Failure to comply with these recommendations
may also result in unscheduled maintenance.<
will result.<
Required fuel
high altitude.
Detergent Gasoline.
As long as it stays that price, I'll keep using 91.
Although, this actually would make a great Mythbusters episode! It would be nice to see some UNBIASED scientific backing to all this.
#85
Originally Posted by mbp727' post='984080' date='Aug 20 2009, 09:37 PM
DAMN what problems have you had with 189k!?
water pump
disa motor
oil seperator valve
i still get 33 highway and 22 city
bimmerspeed
Frequently Asked Questions
09-01-2015 05:09 PM
