what engine oil do you use?
i need to top the engine oil up for my car but im not sure which 1 should i use.
i got the castrol edge 5W-40 for my 2005 E60. is that recommended for E60?
I went on the castrol website n 5W-40 is recommended for my car but then today i searched again and 0W-30 is recommended for my car. so which 1 shall i use? or it doesnt matter?
From a BMW PDF that I downloaded the other day. Hope it helps. I'm using the BMW HPSAE 5W-30.
BMW High Performance SAE 5W-30 Synthetic Oil*
Castrol Syntec European Formula SAE 0W-30
Mobil 1 SAE 0W-40
Pennzoil Platinum European Formula Ultra SAE 5W-30
Valvoline SynPower SAE 5W-30
Use only oils with an API rating of SM or higher.
The choice of the right SAE grade is based on the climatic conditions in the region in which you normally drive your BMW.
Mobil 1 SAE 0W-40
Mobil 1 SAE 0W-40
Mobil 1 SAE 0W-40
thanks, i rang the stealer up n confirmed that 0w-30 is recommended.
