Weatherstrip
My Ride: E60 M54
Model Year: 525i 2004
Hi,
The door on my E60 squeal a bit and I read somewhere changing the weatherstrip might help. Question I have is, that the weatherstip part number comes with two peices, so does that mean one is for the door and one is for the body side or does the body side seal has a different part number?
Thanks.
Thanks.
Drilling down through www.realoemparts.com/bmw may help you find what you need.
For example:
Item #9: http://www.realoem.com/bmw/showparts...19&hg=51&fg=55
Item #1: http://www.realoem.com/bmw/showparts...09&hg=41&fg=40
HTH,
Jim / crewzer
For example:
HTH,
Jim / crewzer
My Ride: 545i 2004, SMG, Sport, Nav, Logic-7, Bluetooth phone retrofit
Have a look at the attached file and see if it describes the problem. Part numbers are in there.
[attachment=173020:SI B 51 02 05 squeaking door seals.pdf]
I just did this on mine. Cost about $220 for all 4 doors, but it works - no more squeaks.
Afterthought: The rear seals can be changed without removing anything else. Not so the front - at a minimum, you have to pry off the bottom end of the metal trim. Push it OUTWARDS, do not pry UP. I found this out the hard way, and busted all the clips.
