the way E60 was meant to be
#651
My Ride: 05 545i
Thanks to all who shared this discovery....turned on the beast in my 545i. ...@ 1800 rpm it starts pulling really hard all the way to 5000rpm....uber quick.....makes second and third gears an absolute blast....haven't taken it out on open road yet...but boy if the back country roads are any indication. ..what a kick in the pants.... $20 for parts and 15min install....now my friend with a 08 535i wants me to transform his
#654
My Ride: e60 550i M-Sport, 6mt
I was very skeptical but tried this mod on my 2007 550i manual trans. My car has the sport package, including active steering and active roll bars.
Much to my surprise, in sport mode the steering becomes much heavier. Almost too heavy for parking lot speeds, but once you get above 10mph I really like the efforts. The throttle response is now more crisp as well. All in all a nice little mod for $10!
#655
My Ride: 545I
This mod is EPIC. I didn't think it would work on my auto 04' 545i, but it absolutely did. I crudely wired up my sport button just to be sure it worked. I plan on coming up with a clean solution this weekend. Not sure what It does to the steering, the best way I can describe it is....BETTER. I mean its just the bees knees guys, and it literally took me longer to read all 60 some odd pages of this thread than it did to set it up.
#657
I was one of those who did this mod (2006 525i Manual), it improved the throttle response, but the steering remained unaffected. Changed the FDC_ID_MONITOR and FDC_VERBAUT in KOMBI module to aktiv, but still did not make any difference. Finally I dug into the SGM module, found SERVOTRONIK already set to activ, but FAHR_DYNAMIK_CONTROL was set to nicht_aktiv. Changed it to aktiv, went out for a test drive and ... voila, the steering now became much heavier as soon as I turned on the sport mode.
So folks, if you want the heavier steering, but it eludes you, now you know the answer.
#658
My Ride: 530i base model
Just finished on my 2004 pre LCi model 530i 6 speed manual. I used oem parts such as the sport switch and tray. I didn't notice any steering wheel affect, heavier or anything else (probably because i am lacking a servotronic) but the throttle response is noticeable more responsive than before like installing a sprint booster!!! Connections are the same as in first page mentioned for pre LCI cars. I have M5 cluster instruments so no "SPORT" indication there just the light of the switch goes on when you press the switch.
![](http://i58.tinypic.com/of91ua.jpg)
#660
My Ride: BMW E60
Engine: E60 M54
Its been a few months since i added this mod to an 06 525. Hands down the best possible
performance upgrade so far and i have a few, Only down side is Mpg drops 40% but i dont mind at all. Thanks forum!!!
