!!!water vapour on the inside of xenon!!!
hi
i don't know how this has happened, it may have happened due to the weather or more than likely when i washed her (525dmsport) last week using a power washer. the question is how can i get rid of the water, i'd rather not take the headlamp out and start messing with it, but if i leave the full beems on say for a hour or two will the vapour evaporate?
the other day it was fully covered with the vapour, but it seems to be getting better, a little a day.
will this cause any damage to the xenon?
pls refer to the jpg below
![!!!water vapour on the inside of xenon!!!-dsc00331.jpg](https://5series.net/forums/attachments/e60-discussion-2/67217d1482365736t-water-vapour-inside-xenon-dsc00331.jpg)
member dandle had a similar issue, so have a few other members...all took the car to the dealer and had the headlight unit replaced (under warranty).
have a look at this thread..
http://forums.e60.net/index.php?showtopic=67146&hl=
My Ride: 05' 545i
Originally Posted by parmblagan' post='745571' date='Dec 15 2008, 11:04 AM
i check out the above but i aint got warranty anymore
Originally Posted by rrnag30' post='745576' date='Dec 15 2008, 08:10 AM
the seal is no longer "vacuum" tight... this will be forever a reoccuring issue. you will have to replace the unit
I'm not sure they were vacuum sealed in the first place... many have had condensation in the headlights but not to that extent.
See my pics in post #11
http://forums.e60.net/index.php?showtopic=3861
My Ride: .
Model Year: .
Iceman's response from the 1st thread-link above,
Since you're out of warranty already, I'd give it a few days to let it clear up on its own before doling out $$ for a replacement set. If the problem appears to linger longer than expected then I'd consider replacing it.
Originally Posted by Iceman' post='47654' date='Oct 21 2004, 03:33 PM
I talked to my dealer about it today when I dropped off my car. He told me it is nothing to worry about, as long as there isn't water drops in there. The lights are not totally closed, so that the heat can get out, so a little bit of condensation is OK.
Vman33
03-14-2022 04:43 AM
timmay77
09-24-2015 09:38 AM
DetailersDomain
Detailing Forum
09-22-2015 03:59 PM
ucsbwsr
09-19-2015 10:58 AM
