Water in steering column
Old Mar 24, 2013 | 07:45 AM
blutoon5series's Avatar
My Ride: 520d
Default Water in steering column
Guys looking for some help with a water issue. My car was accidentally hit with water at the steering column 6 days ago. Since then the wipers have been in emergency mode, no buttons on steering wheel work, no indicators, no cruise control and I drive did fail but is now back working. Indicators and full beam have now just started to function although this is only when lights on and happens without touching anything. Can someone please advise me what could be done to solve this issue. It also says on Idrive that the ignition is faulty and could be started by depressing the foot brake, also DTC does not work either.
Old Mar 24, 2013 | 01:55 PM
H F's Avatar
H F
My Ride: 2005 545
I would try chasing the water out with a little wd 40.. Or some kind of electricl contact cleaner. u might have to take all the plastic covers off every thing and see if u can see all the electrical contacts. and clean them out..
Old Mar 25, 2013 | 02:58 AM
My Ride: 520d
I have been told i might have to take the airbag off and get to the connections that way? if this is the case how easy it to take this off?
Old Mar 25, 2013 | 09:49 AM
H F's Avatar
H F
My Ride: 2005 545
I dont know.... make sure u search it and get info be for u attempt it.... or maybe one of the Pro's here can chime in on the procedure,,,,
Old Mar 31, 2013 | 06:05 PM
Gee_115's Avatar
My Ride: 07 550i Sports Package
Get a long screw driver not too thick, there is a hole under the steering wheel pop the crew driver in there and the air bag should just pop out. If you don't understand then do a search on you tube to see how to take off the airbag.
However, your problem may be the steering column switch that is the control for the electronics in that area.
V70Cat
Jan 16, 2019 12:18 PM
Sou1b1azer
Oct 14, 2015 06:55 PM
nuklep
Aug 20, 2015 06:40 PM
CVTBenhogan
Jul 13, 2015 06:46 AM
jeffandjaimie
Jul 8, 2015 05:48 PM
