wanting to install nav in my 2004 545i im a newbie
just woundering what i need to install navigation in my 545i and the easiest way. and if anyone knows were i can get head gaskets and how hard they are to change.and i also noticed my back tires wear more on the inside then anywere else they toe out ! but i heard that is normal for bmw.
if you have any info on any of this it would be a great help ! i dont know what the (ccc, or cic) stand for either.
thanks
chad
thanks
chad
CCC is the DVD based nav and would be the cheapest option (1000 to 1500). CIC is the newer hard drive based nav and priced higher (2000+). You can find the CIC for cheaper than I listed but once you read the fine print you'll see that the price starts to climb after you add map activation and other coding.
The coding of the CCC based system can be done with a laptop, cable, and downloadable software. I've read where people have been able to code the CIC system but I don't think map activation is a DIY on that setup, I could be wrong though as I don't follow the CIC upgrade as closely. Many sellers offer the CIC system fully activated and basically plug and play, but the price is pretty high. Read the fine print before ordering.
Wasn't there a member, Patry or something like that, selling CIC upgrade unit? Search for CIC upgrade and you should get lots more results.
GL OP.
Wanting to do this down the line also so please do keep some of us updated.
GL OP.
macantley
03-31-2015 03:44 PM
