V1 Hardwire Problem
Old 01-02-2005, 01:42 PM
Bokke's Avatar
Thanks Gents,
I re-crimped (sp?) the connector and it's working!
I just hoped I did'nt screw anything up
Cheers,
Old 01-02-2005, 01:44 PM
bklyn545's Avatar
My Ride: 2011 535i... Alpine White, Black Dakota, Anthracite, Premiium 1+2, Sports Package, Comfort Access
Oh and if youre screwing the ground connection into the roof of the car you should scrape the paint off to ensure you're getting metal on metal contact.
Old 01-02-2005, 01:45 PM
bklyn545's Avatar
Originally Posted by Bokke' date='Jan 2 2005, 04:42 PM
Thanks Gents,
I just hoped I did'nt screw anything up?
Cheers,
[snapback]74769[/snapback]
OK good!
Old 01-02-2005, 04:05 PM
JDN
JDN's Avatar
Originally Posted by bklyn545' date='Jan 2 2005, 04:42 PM
[quote name='JDN' date='Jan 1 2005, 07:19 PM']I used the V1 connector successfully. The green and yellow wires are the switched 12V connections. My connector took a minute or two to finish biting through the insulation after I clamped it. I has been working like a charm since. I hooked into the yelllow/green wire going into the rain sensor and grounded on one of the screws into the body overhead. Be sure you are well grounded.
[snapback]74496[/snapback]
The V1 connector should work but the red connector is a more solid connection. I was afraid that if i kept trying to really clamp down on the blue connector in order for it to make a good connection i was going to go straight through the wire. Ive done this install on three cars so far and i found the red connector to be the best bet.
[snapback]74768[/snapback]
[/quote]
Gotcha. Thanks.
gergnang
02-02-2021 07:29 AM
bbbamboo
09-17-2017 04:33 PM
RussHamel73
06-03-2015 08:24 AM
gaz
05-29-2015 06:11 AM
E60Japanese
03-23-2015 05:23 PM
Quick Reply: V1 Hardwire Problem
