Updated Service on NAV not knowing where u are
Old Mar 22, 2006 | 06:28 PM
cobradav's Avatar
SI B 84 10 05
Phone, Navigation Systems March 2006
Technical Service
This Service Information bulletin supersedes S.I. B84 10 05 dated November 2005.
(New) designates changes to this revision
SUBJECT
CCC Navigation Displays Incorrect Vehicle Position
MODEL
E90, E91 (3 Series) with SA 609 (Navigation System)
E60, E61 (5 Series) with SA 609 (Navigation System)
E63, E64 (6 Series)
SITUATION
The customer may have one or more of the following complaints:
Incorrect vehicle location is displayed.
Map displays only background color, no streets.
Route Guidance cannot be started.
(New) Route cursor moves to incorrect route.
(New) HIP (Host Independent Positioning) module cannot be initialized.
(New) CCC does not update the location when the vehicle is in motion.
The following fault may be stored in the CCC-A (Car Communication Computer ? Applications)
"A062 ? No communication with Hip module"
CAUSE
HIP module software/hardware
[color=#FF0000](New) PROCEDURE
In the event of a customer complaint diagnose any faults stored using the DIS/GT1.
Update the complete vehicle per SI B09 05 01 (Coding, Individualization, Programming) Procedure B, using Progman 21.00.00 (Target Data Status E060-06-03-510, E89x-06-03-510) or higher.
After programming is completed, It is very important that the vehicle is driven for at least 15 minutes with good GPS reception in order to determine the vehicle location.
If the problem is not resolved, submit a PuMA case to the Electrical Group.
Wait for further instructions from the Electrical Group.
Kasmo
May 7, 2019 03:30 AM
2004_545i
Apr 8, 2015 04:01 AM
rackhacker9275
Apr 7, 2015 12:31 PM
Beemer
Dec 22, 2003 11:23 AM
