Transmission Solenoid Replacement and Oil Questions
Old 06-27-2014, 11:48 PM
mwaku's Avatar
My Ride: BMW E60 530i
Ok transmisson solenoids been swapped out along with sealing sleeve, sealing adapater, oil and pan+filter.
Cars not jerking anymore so problem solved? BUT
Shift is rough between 1st and 2nd, when going up or down. Kinda like a thump. :\ hoping this is just due to the lack of learning and hope it goes away later\\
Thanks for all the help KyleB
Old 06-28-2014, 04:35 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
Did you reset adaptations using INPA or a similar tool? This is vital.
If you did reset adaptations, give it a few hundred miles. The TCU needs time to adjust shift points and pressures to compensate for your driving habits and normal clutch wear inside of the clutch packs.
Yes, perfectly normal. Mine did it for a couple hundred miles, especially 1-2 and 2-3 upshifts.
Old 06-28-2014, 06:40 AM
mwaku's Avatar
Yep, reset via INPA and later the 'reset' via the pedal to see if this might add help lol
Old 06-28-2014, 08:26 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
doing it via the pedal won't do anything 'extra'. in fact, if you've reset it with INPA, just leave it alone and let the TCU do its thing. How many miles have you put on the car since you did everything?
Old 06-29-2014, 05:35 AM
mwaku's Avatar
under 500....
Old 06-29-2014, 07:44 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
under 500....
Give it more time.
socale39
09-05-2023 08:30 AM
biggie550i
04-02-2015 09:27 AM
fmusbmw
Bluetooth & Cell Phone Forum
05-14-2004 11:41 PM
brian1225
04-16-2004 05:59 AM
08-12-2003 11:41 AM
Quick Reply: Transmission Solenoid Replacement and Oil Questions
