Transmission Problems 4E87 and 4F86
Probation Members
My Ride: 2005 BMW 525i
4E87 solenoid valve 4 (shift lock) P0982 Solenoid valve 4 control circuit -
low Error counter: 2 Logistic counter: 40 1. Environment set Mileage 98 104 km State of WK converter clutch open 0-n Switching type Switching type P to P 0-n Gear oil temperature 48.00 degrees C Supply voltage DR / MV 13.60 volts Target state M1 (0 = off 1 = on) 0.00 0/1 Target state M2 (0 = off 1 = on) 0.00 0/1 Target state M3 peek phase (0 = off 1 = on) 0.00 0/1 Target state M3 Hold Phase (0 = off 1 = on) 0.00 0/1 Target state M4 (0 = off 1 = on) 1.00 0/1
4F86 Gear ratio monitoring Symptom circuit monitoring
4E87 and 4F86
i have the 2 codes via inpa
What is my problem?
4E87 and 4F86
What is my problem?
Followed that on my X5 like you did no problems, different beast that I'm use to. 192.168.100.1 192.168.1.1
gil_g
Dec 2, 2021 10:05 AM
