Transmission problem
Old Feb 7, 2019 | 01:56 AM
Stoney123's Avatar
My Ride: 08 bmw 528i
Default Transmission problem
I’m getting code 17e5 don’t know what this is but my transmission goes into limp mode when I get down in my gas! I have to pull over restart car and it drives fin until I do again! Any help please!!
Old Feb 7, 2019 | 09:18 PM
Vlad525's Avatar
My Ride: E60 525DA
Engine: 525 M57 straight six @225BHP
Hi Stoney, seems that you have problems with the E clutch. Take a look here,
https://axleaddict.com/auto-repair/Z...E-Clutch-Fault
Hope that helps.
Old Feb 8, 2019 | 09:52 AM
tttomttt's Avatar
My Ride: 2005 530i
Model Year: 05
Engine: m54
Stoney
I have had my e60 only a few months and was quite surprised when taking my car on a extended run to see family that as I attempted to pass another vehicle my car bucked a bit and went into failsafe mode. As many of us have stated shutting the car down briefly and restarting returned the car to normal operation. When I scanned the car with my Foxwell scanner I came up with code 4F85/ not present EGS: ratio monitoring, clutch E. When I researched this code it referred to a bad bushing for the shaft for E clutch. I also found several articles relating to valve body, solenoids, low on fluid etc etc. I have been turning wrenches since I was seventeen and as cars became more and more complicated I have found in my 43 years as guy working with my hands not all codes reflect the problem accurately. After much research and even a discussion with a terrific transmission guy down the street from me I decided to do the mechatronic kit (I used Pentosin fluid) and replace the valve body with a rebuilt one through RevMax. I was able to reset the transmission adaptions on the car and today for the first time really take it out for a hard drive. I am pleased to report that none of the original symptoms are present in the car. The upshifts were smooth as well as the downshifts even the second gear to first as you stop was no longer feeling funky. I am very relieved. I subbed out the work to my transmission guy as I at 61 yrs old did not want to lay under my car in the winter doing this service. If I had had access to a lift I would have been all over it. Be advised all symptoms are different, however I thought I would relay my story to you.
Tom
simplemind
Aug 11, 2009 07:37 AM
tiptronic
Feb 8, 2006 10:39 AM
oreo
Oct 3, 2005 04:57 AM
dvw
Jul 7, 2005 05:17 AM
PuRePLaYaZ
Jun 21, 2005 06:24 PM
