TPM acoustic warning disable
My Ride: E60 550i
Model Year: 08
I'm sure you are experiencing problems with TPM in low cold temps, the warning message "TPM Malfunction".
Just to clarify this is not low tire pressure warning and the trunk is bone dry.
It remains active during all the time if outside temperature is low (like below 20) and every few seconds it makes acoustic sound warning that becomes annoying during the ride.
Is there a way to disable the sound?
Huh? I have had temperatures down to -20 and no problems with the TPM alarming. Also, have you tried resetting the TPM system in the i-drive?
