TMBF Control Unit Fault 96E3 / 96F2
Dear ALL, I am having a problem with the Door Module, with fault code 96E3 and 96F2 for TMBF, and 9B4F for TMFA.
For the TMFA, it shows the Swtich block, data transfer, but my swtich block is working perfect normal,
For TMBF, I have search through the web for the definition for 96E3 and 96F2 but no luck to find anything about these...![Bashwall](https://5series.net/forums/images/smilies/imported/bashwall.gif)
Please if anyone could give me some idea what's happening...
Thank you
Thank you
Thank you
Thank you
I am having same problem, just wondering if you've found the fix and mind to share?
Thanks!
