tire pressure
I find that compared to GPS my speedometer seems to register that I'm driving faster than my actual speed by a few mph (e.g. speedo = 65mph / GPS [actual?] = 62mph)
My bad! That's what I mean in fact. The math still works though - if the speedo shows 5%+ on stock tires, using non-spec tires (40/35 in this case) should get you to a more correct speedo reading. Or not?
Aside from speedo error or correction ... IMHO clearance / rubbing is the other factor to keep in mind when considering tire-size changes. And minor (+1) upsizing usually doesn't require rim-width changes but going to extreme can stretch the tire and distort it's contact patch - actually degrading performance.
My Ride: M3 ZCP EX:2005 BMW 535D Sport, Estate, Steptronic, Carbon Black, Black Dakota leather, Head up Display, Profi Satnav, Bluetooth - only MULF module, Bi-xenon adaptive headlights, Sportseats, Cruise control, Active steeringMods: 19
Model Year: 2011
I'll try to do some pictures tomorrow and post them here.
My Ride: Mine: 2005 545i Sport Pkg, Black Saphire/Black, Nav, Chrome Wheels ---------- Wife's: 2007 335i Sport/Prem Pkg, White/Auburn, Nav
Mmmm... I have stock 18" on mine and I run 36 psi front and 44 rear. It seemed odd at first but that's what is stamped on the door.
My Ride: 2012 535i X-driveSpace Grey/Black Dakota, Fineline Anthracite Trim; Executive Package (Rear View, Lumbar, Nav, Voice, SIRIUS, HiFi Pro) Technology Package (Hi Beam Assist, Lane Departure, Blind Spot Detection, Surround View) BMW Apps (Apps, Smart Pho
Model Year: 2012
My 2008 535i door jamb shows 32 front and 35 rear for 19". Surprising that that is the same for 17" as well. The max for rears can go to 38 psi.
laro1965 has Sport pack which may be higher than my non-sport listing.
Confused yet?
Confused yet?
My Ride: 2004 545i
Production date: 02/04
Color: Black Sapphire Metallic
Trim: Anthracite
Options: Sport package with STEPTRONIC, Premium Sound, Rear Sunshade, Xenon
Khooger, you mentioned that you also run with 32/36 psi -- your 545i has sport package as well but you have 19" tires instead of my 18" ones. Did you just pick that by trial and error or you prefer it that low?
