Tank Venting Valve
My Ride: Navy 550I
Hey can anyone help me on explaining what's a Tank Venting valve? My car was originally brought into the stealer for a white smoking problem, and the stealer called me today and said it was the Tank Venting Valve that was causing the vehicle to smoke. Could this be true? Thanks In Advance!
Oh and they want 400 bucks to repair it!
Jezzz
Jezzz
My Ride: Titanium Silver 2008 550i 6MT. Matte black grille and numbers. Carbon roundels. Eibach springs and sway bars. Bilstein struts. UUC SSK. Smoked LED side markers.
The tank vent valve is usually the valve that allows the fuel vapors from the carbon canister into the intake to be burned. I doubt it could cause white smoke. White smoke usually means your car is burning coolant. Is the coolant level low? When do you get the white smoke?
My Ride: Navy 550I
Im sorry..the reason I asked is due to the fact that my 04 545 has been smoking lately. After the car sits at idle, if I rev it up it will smoke out and then eventually go away. Just curious if that was the same problem. To be honest though it is not a consistent problem. If you have had the same problems please inform me what is it you have had changed and let me ask my indy shop about it. Thanks
My Ride: Navy 550I
[quote name='saf545' timestamp='1314547806' post='1376577']
[/quot
Yeah bro the car would smoke out; check to see if it has oil, and use the dip stick to check the oil level.
[/quot
im having the same problem saf your having, some are telling me its a valves, im really interested to know where this part is located could be the source of our of problem
Vman33
Mar 14, 2022 04:43 AM
EuropeanArtz
Sep 23, 2015 08:21 PM
umichchris
Sep 10, 2015 12:54 PM
... WTF!!! That's not good at all!!!
