SZL Module
Old 10-13-2010, 04:11 PM
THNG0's Avatar
I had those lights came on before but my is not a AWD. Its possibly could be steering angle sensor. Try stay in park and turn your wheel left and right several times see if the malfuction come up. If is it then it have to the steering angle sensor. What i did was pulled the sensor out, took it apart and clean it. Since then it works fine.
Old 10-13-2010, 11:17 PM
balbs's Avatar
My Ride: BMW
I had the same issue as post #10 above. Mine is not AWD though. I had the SZL replaced (fortunately under warranty) however, the part was about $550. When I got it installed, the tilt steering adjustor didn't work so they had to reprogram that function back in. Check out this thread:
http://www.bimmerwerkz.com/forum/5-s...ult-68407.html
Good Luck!
Balbs
Old 10-14-2010, 08:23 AM
DanP's Avatar
My Ride: 2008 535xi Platinum bronze metallic, automatic, cold weather package, fold down rear seats, iPod adapter
Originally Posted by syrus_aka_buratina
Hello folks. I recently got this 2006 BMW 530xi with 64k miles on it. Now I see the brake light always on and the AWD malfunction (see attached files). Dealer changed the brakes and rotors (so they are in pretty much brand new condition) Car is out of warranty so I'm gonna have to pay for it myself. So I brought it to one of the car shop and after diagnosting it for a while I was told that I have problems with the Transfer Case. In a first place they thought it was a Steering Angle Sensor, but after checking it was just fine. The brand new parts + labor would cost me ~ $2,200 or $1,800 for used ones.
So I wanted to get a 2nd opinion and brought it to 12V (the other shop in Brooklyn, NY). Now these guys keep telling me that my problem is the Steering Column Module (est. cost is ~ $900)... I am confused. Don't want to bring it to BMW dealer since only diagnostics might cost me more than the cost of the parts. Neither I want to pay for the parts that are working fine at this time
Please help!
I had those exact same symptoms and the solution was just a new battery.
Old 10-14-2010, 08:30 AM
Cwest's Avatar
I had the same issue before with wipers and sealt belt restraint and others poped up at the same time. I freaked out and disconnected the battery and let it sit for a bit then restarted and it was fine after that. I just hope it doesnt do that again.
derooster
09-22-2016 07:30 AM
CHRGRS_BMW
38
09-01-2016 09:39 AM
Sou1b1azer
10-14-2015 06:55 PM
endukas
07-12-2015 12:06 AM
jeffandjaimie
07-08-2015 05:48 PM
Quick Reply: SZL Module
