Stereo power will not sleep. Need switch or relay ..
Old Jul 31, 2011 | 08:09 AM
Deano's Avatar
My stereo power will not go to sleep after after the car goes to sleep, causing overnight battery drain. I am out of warrantee and don't want a $1000-2000 bill from the dealer to diagnose and eventually replace my stereo headunit.
I got an idea from the DIYMA stero forum to add a switch that will turn off the remote power of my system, thus de-energizing my three amps in the trunk.
Instead of a manual switch, which I could forget to activate before leaving the car, I would like to add a spst relay to power this circuit. My question, where in the trunk should I tap into a 12v source to energize the relay? Hoping of course that this source WILL sleep when the car goes to sleep, and turns on when a door opens etc.
thanks,
Old Jul 31, 2011 | 08:55 AM
healthservices's Avatar
Have your battery tested first, a weak battery will cause a lot of problems, For example if a fan cycles when the car is shut off and the battery voltage drops below a certain point some relays will not shut off, causing the draining of the batteries.
Old Jul 31, 2011 | 11:32 AM
Deano's Avatar
Battery is new and good, alternator is good, IBS sensor is brand new. The radio will not go into sleep mode and is draining my battery. I am unable to diagnose further so I am content in cutting the radio's power when exiting the car. I could do it through a switch, but i'd rather turn it off automatically utilizing radio fuse #34 in the glove box. I just need to figure out the best power source for the relay and the bits & pieces to put it together.
mmarco50
Jul 25, 2015 11:17 AM
zukgod1
Jul 14, 2015 10:19 PM
Bank$hot530
Jul 12, 2015 04:36 PM
ferrary01
Jul 9, 2015 12:38 PM
jeffandjaimie
Jul 8, 2015 05:48 PM
