Start Button stays lit
Old Apr 25, 2008 | 08:00 PM
FiveThirtyI's Avatar
My Ride: 2008 M5 Saphire - All available options 2006 530i Mystic Blue - All available options for 06 2004 Ford Expedition - Boat hauler.
I noticed the Start Button on my 535i stays lit. The car has not been driven in over a week and when i opened the door the car made all the normal sounds of waking up. Does anyone know if this button is supposed to stay lit?
Old Apr 25, 2008 | 08:09 PM
Gene's Avatar
when you open the door it should stay lit, turns on again when you insert your fob...
so are you saying that after you pull your key fob out, exit the car, close the car door and lock the vehicle via key fob that start button still stays on?
Old Apr 25, 2008 | 09:26 PM
Yes, it remains lit even after the car is locked and the fob is not in the car. I should have also mentioned that I have Comfort Access so I rarely insert the fob.
Old Apr 25, 2008 | 09:29 PM
Gene's Avatar
ahhh...not sure if having CA could have something do with it, but I'm sure members will chime in...good luck with it...
definitely might want to post some specs in your prof or sig regarding your e60 as it helps answer q's...or if you don't mind typing it everytime then u're good...
good luck, keep us posted fellow so cal'er...
Old Apr 26, 2008 | 09:15 AM
ObD's Avatar
ObD
My Ride: 2008 535i 6MT
The button will stay lit for ~15 min. It's normal.
Old Apr 26, 2008 | 10:47 AM
Roleez's Avatar
My Ride: 2011 E92 335i M-Sport 6MT
Exactly. My old 550 didn't have Comfort Access and my M5 does. Both cars act the same way. After ~15 min. of inactivity (no doors opening or pressing buttons on the key fob), the car enters its 'sleep mode' and the light on the starter button goes out.
Old Apr 26, 2008 | 11:21 AM
iversonm's Avatar
My Ride: E46 330, E60 550 on order: Carbon Black/Natural Brown, 6MT.
It will turn back on if you do anything to wake up the car. Try opening the trunk without the fob in your pocket. The trunk won't open, but the car will wake up.
Old Apr 26, 2008 | 11:50 AM
Ricracing's Avatar
In my car the auto shifts "P" stays lit after closing doors.
Old Apr 26, 2008 | 08:27 PM
ObD's Avatar
ObD
That will also go out in ~15 min.
DavaiLave
Aug 2, 2022 02:16 AM
patallen
May 30, 2015 01:06 AM
drifts500
May 18, 2015 05:10 PM
spitfire23
May 12, 2015 04:23 AM
gaz
May 6, 2015 03:28 AM
