Stable power
Old 10-27-2019 | 08:37 AM
scottalexander's Avatar
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
Default Stable power
I was just reviewing stable power supply vendors. Particularly the:
- Schumacher power supply model INC 700a
- Deutronics stable power supplies
Are any of the Schumacher stable power supply products currently re-branded under a different name ?
Have you come across a brand that is more price competitive than the Schumacher products ?
Old 10-27-2019 | 08:55 AM
audiophool's Avatar
My Ride: 535xi
What are your needs? Do you want to do extensive programming and want a steady 14.4V attached to the car for this reason? If that's all you're after, it would be pretty easy to build a 20-30amp power supply with fixed output for 1/4 of that. Or buy an 'off the shelf' supply. I found a 50A 12V SMPS on Amazon for $50.
Old 10-27-2019 | 11:36 AM
My Ride: 528i
Engine: N52k
The only work I do is with Insta and INPA.
I was getting ready to use the software to bleed the ABS, DSC pump, calipers and the battery was getting weak. I knew I needed a constant power supply and have been putting it off.
I'm just looking for a constant 13 volts for about an hour. If I had this device in the garage I'd use the BMW software a lot more often than I do.
You say you have a 50A 12V SMPS from Amazon.
Did it come with alligator grips you could attach to the positive jump block under the hood? Which 50A 12v unit do you have?
Old 10-27-2019 | 12:47 PM
audiophool's Avatar
My Ride: 535xi
Like this:
Amazon Amazon
You can tweak the output a little. Attach your own leads. A smaller one would probably suit the needs, say 20-30A.
Amazon Amazon
But I've never had a problem just using a battery charger I got from Crappy Tire: https://www.canadiantire.ca/en/pdp/m...1976p.html#srp
Old 10-27-2019 | 04:05 PM
My Ride: 528i
Engine: N52k
Looks like our day just got better.
The Schumacher 100 power supply used by many is $727
Schumacher rebrands this unit and calls it a DSR.
The DSR is $379. See below.
https://www.pepboys.com/dsr-power-su...product/216232
I can live with $379.
Old 10-28-2019 | 07:58 AM
audiophool's Avatar
My Ride: 535xi
That's good news. I'd suspect that Amazon is hiking the price, but that's just me.
Old 10-30-2019 | 10:27 AM
My Ride: 528i
Engine: N52k
In conversations with Noco (who makes power products), they tell me their model G7200 can operate in power supply mode.
The Noco G7200 power supply mode delivers 13.6v continuously at 5 amps. It can be connected to the terminal block under the hood for circa 3 hours before it over charges the battery.
If you are doing diagnostic work with Inpa, Ista (e.g. bleeding the DSC and calipers) and find that your battery is going dead, it appears this Noco power supply could be a solution. Its circa $99 and a lot cheaper than the Schumacher model 100 for $722.
If you are updating, flashing the Schumacher power supply at $722 is going to be in your best interests.
Anyone have experience with the Noco G7200 in power supply mode?
Old 10-30-2019 | 07:43 PM
audiophool's Avatar
My Ride: 535xi
No experience with that one, but I wonder why they say that it'll overcharge the battery after 3 hours if it's set to output 13.6V. Ideal float charge for a 12V battery is 13.5V, so an extra 100mV shouldn't be a concern.
Maddog-99
08-21-2012 11:17 AM
abnovak
12-11-2008 06:10 PM
vishwen
06-22-2008 09:48 AM
KMonster
15
03-05-2005 12:12 PM
Doctor Diesel
06-10-2004 07:16 PM
Quick Reply: Stable power
