Some Questions About my New 550i
Finally got my car back after a week, everything seems to work great. Ipod issues are solved now when i go back from an album to main list it actually goes back where i entered from instead of going all the way back to "A" I know they updated the software but not sure if only certain modules were updated.
Here are a couple of jobs in their words:
E60 E61 E87 E9X (with SA 06FL) Replacing electronic charging
CAUSE: Locked up SI. RE-RE Spare Wheel. RE-RE charging module.
Installed new charging module. Program new module. Encoded. Will not Encode the SZM. Performed Encoding on just the SZM now it has encoded.
Initialized ARS DSC IHKA
PARTS: 84-10-9-187-625
E60 E63 E64 E70 N62/TU RETROFITTING GROUND CABLE. ENGINE COM
CAUSE: RE-RE Sound proofing cover. RE-RE Ingintion Covers, Installed both LH and RH Ground Straps.
CORRECTION: Retrofit engine compartment earth cables 00 57 127
9 FRU. Defect code 00 12 51 02 00
PARTS: qty2 12-52-7-581-845 SUPRESSION BAND
BMW ASSIST CANNOT FIND LOCATION OF VEHICLE
CAUSE: Tried to intialize BMW Assit but failed. BMW provided new numbers to TCU. Perform Intialize again-services could not be intialized shows on CID.
Leave vehicle to sleep.
Re-initialized after leaving to sleep. Progress bar shows complete. Operator can now LOCATE the vehicle.
They also adjusted HUD by hooking up to their computer.
It doesn't state they updated the software but either way everything seems to be ok now.
ANOTHER QUESTION: I was able to get the icons to show up but when i choose GAS STATIONS it shows the icons but as soon as i choose anything else (banks, ATM etc) the first icons dissaperas, is that normal? It only shows ONE ICON at a time? My Honda shows everything.
Thanks
Thanks
My Ride: 2008 BMW 550i
2006 BMW X3
Thanks
Thanks
Re icons, yep, only one at a time.
