solenoid help!!!!
My Ride: 2004 BMW E60
![Exclamation](https://5series.net/forums/images/icons/icon4.gif)
i changed my solenoids, sealing sleeve and gasket between transmission and mechatronik and im getting a transmission error on my i drive when i scan it i get a error code saying solenoid d (shift lock) and solenoid d circuit low what does all of this mean? i have not driven the car as yet i fill the transmission with oil went through the fill process i haven't reset the adoptions as yet im wait on the INPA/OBD2 cable do you think its because i haven't reset the adoptions im getting that code? which solenoid is d? i ordered them from ctsc.com im going crazy over here not a fan of auto trans nor the dealership
thanks![Angry](https://5series.net/forums/images/smilies/imported/angry.gif)
thanks
My Ride: 2008 550i
I wonder if this is related to forgetting to set the park cylinder rod when reinstalling the mechatronics unit. If you are unable to shift out of park, this would be the cause.
Yes i sorted out that problem while i was working on the transmission i didnt disconnect my battery nd i switched di ignition on while the transmission was pulled down so it throw that error message but after disconnecting the battery for a few seconds it cleared. My car drives good smooth shifts #LikeNew
I've found out that the shift lock solenoid is not in the transmission it is where the shifter is and over a period of time sometimes dirt and coins can get in where the shifer is and mess with the solenoid. That is a next way of finding if that is the issue at hand or def your transmission.
