solenoid help!!!!
i changed my solenoids, sealing sleeve and gasket between transmission and mechatronik and im getting a transmission error on my i drive when i scan it i get a error code saying solenoid d (shift lock) and solenoid d circuit low what does all of this mean? i have not driven the car as yet i fill the transmission with oil went through the fill process i haven't reset the adoptions as yet im wait on the INPA/OBD2 cable do you think its because i haven't reset the adoptions im getting that code? which solenoid is d? i ordered them from ctsc.com im going crazy over here not a fan of auto trans nor the dealership
thanks :angry::angry::angry: |
Hey did you ever sort out your problem?
I wonder if this is related to forgetting to set the park cylinder rod when reinstalling the mechatronics unit. If you are unable to shift out of park, this would be the cause.
Originally Posted by dingolfing
(Post 1555803)
issue solved
Originally Posted by ranger530i
(Post 1555745)
(Post 1555803)
