SMG Gone?
Old 08-31-2005, 08:10 AM
  #41
Banned
stream's Avatar
Originally Posted by pennetta' date='Aug 31 2005, 06:26 AM
Even though its called a sequential manual gearbox, its not. My Kawasaki ZX1000R is a true sequential, you must go through each gear to get to the next. Its a mechanical linkage so this is obvious. The E60 is relatively standard 6-speed manual with a computer selecting each gear. If you had a mechanical linkage you would be shifting with the modified H-pattern, which has neutral as the center point but you can access any gear directly going through the neutral position.
The heard/read the new M5 has a true sequential unit, like my ZX1000R, designed specifically for this use. This maybe why the SMG option has been suspended for the std E60, so they can convert over to the new tranny design for the rest of the line.
[snapback]165528[/snapback]
Silly me--I thought SMG was a sequential gearbox--you know, a Sequential Manual Gearbox!!! I stand corrected!
Mihainede85
03-26-2023 07:49 PM
PakiBeamer
12-09-2016 04:40 AM
Jiawei Zhao
10-21-2015 08:46 PM
bestofthebest
10-02-2015 03:21 PM
LILBZ3
09-27-2015 08:06 PM
Quick Reply: SMG Gone?
