Seat heating issues
Old 12-17-2009, 08:15 PM
vkhong's Avatar
Model Year: 2010
Happened to me. The seat pad wiring harness was loose. Reconnecting the wiring harness was the fix.
Old 12-17-2009, 11:59 PM
E60Sim's Avatar
Thank you all for the great replies !
I'll check if there's a loose connection under the seat during the weekend. However the loose connection theory seems to be pretty weak for me, since the upper part (back) of the seat has excellent heating.
About the recall issue: The airbag sensor was changed under warranty during 2004, due to an error in the airbag weight sensor in the passenger seat.
Old 12-18-2009, 04:55 AM
bzq
bzq's Avatar
I have this same issue, one part doesn1t heating , sometimes it works normally but sometimes. Can you show where I can check those wiring harness.
Old 12-18-2009, 05:12 AM
vkhong's Avatar
Model Year: 2010
When it happened to me, the seat bottom was not heating, but the seat back was. Fixing the loose wiring harness caused the seat bottom to start heating again.
If not a loose wiring harness, your seat bottom could be worn out or burnt out.
Old 12-18-2009, 05:17 AM
E60Sim's Avatar
Thank you!
Excellent ! I'll check the wiring ASAP Winter + leather = cold.
Old 12-18-2009, 05:32 AM
vkhong's Avatar
Model Year: 2010
The forward facing plastic trim under the seat is detachable. There should be some wiring harnesses behind it. I don't remember which one it was. I felt all of them and pressed each one together. I don't remember if there was a "click" or not. The seat bottom heater started working again after that exercise.
I accidentally kicked the plastic trim loose while entering/exiting the vehicle. The plastic trim must have snagged a wiring harness loose and caused the seat bottom pad to stop heating.
Old 12-21-2009, 09:06 AM
E60Sim's Avatar
I've now tried to "reconnect" every wire under the seat, and the heating in the seat (seat pad) still doesn't work.
Does anybody have a schedule of the wires under the seat? I would like to try one more time, before I give up and go to the dealer.
Old 03-03-2010, 01:04 AM
E60Sim's Avatar
Update:
BMW told me yesterday, that the heating-pad is broken. Cost ?650 + labor :thumbsdown: to install a new heating-pad.
It's cheaper to buy a slightly used comfort seat on ebay !!!
I'll see if I can change the heating-pad myself a warm summer day.
dsummersm3
11-14-2019 07:50 AM
rackhacker9275
26
04-16-2015 08:13 AM
zone5
03-27-2015 08:34 AM
james69z28
03-23-2015 06:45 PM
06-17-2003 09:38 PM
Quick Reply: Seat heating issues
