Safety Recall Campaign 05V-504: Parking Lock Guide Plate
Old 11-21-2005, 09:30 AM
cobradav's Avatar
SIB on safety recall re: topic
Also effects X5 and 7 series
http://www.bmwtis.com/tsb/bulletins/bullet...mp/B240605g.htm
File Type: pdf
File Type: pdf
Old 11-21-2005, 10:12 AM
znod's Avatar
Thanks c....dav. I will check both of our cars out.
Old 03-09-2006, 09:46 PM
havard@haslerud.no's Avatar
Does anybody now if this problem might be an issue for European diesel models?
The automatic transmission in question is that used in any diesel models?
Old 03-10-2006, 02:20 AM
cobradav's Avatar
Well yes the tranny is the same as used on all V8, I6 (Petrol and diesel) models, but this recall specifically identifies the specific engines / tranny combo as the problem. But remember as well, these are released by BMWNA meaning the original data could have included diesel engines but was stripped out as NA does not use diesel. I have assumed that many of the gaps in the number sequence for SIBs in NA is due to the original SIB released by BMW in fact being for models in ROW and therefore did not have applicability to NA market. But I could be wrong.
I can only suggest that for a safety recall any market impacted would have been notified.
Old 03-11-2006, 07:37 AM
DD694's Avatar
My Ride: 2006 550i Sport Package, Cold Weather Package, Premium Sound Package, Comfort Access, Xenon Headlights, Adaptive Headlight Control, Navigation System, Steptronic Transmission. Silver Gray Metallic with Gray Leather. Added Red rear reflectors. Swapped stock Style 124 wheels and Bridgestone run-flat tires for BMW Style 125 5-Double Spoke wheels, 8" x 19" front, 9.5" x 19" rear with Michelin Pilot Sport PS2 tires, 245/40YR-19 front and 275/30YR-19 rear.
Thanks, Cobradav. The SIB lists serial numbers of affected cars. Mine is out of the range. Your timely posting of SIBs is greatly appreciated.
Bounce
05-04-2019 01:32 AM
Syafiki
E39 Discussion
07-10-2015 06:49 AM
Ticomystico@gmail.com
07-10-2015 05:19 AM
Lomag
07-12-2004 04:09 AM
08-12-2003 11:41 AM
Quick Reply: Safety Recall Campaign 05V-504: Parking Lock Guide Plate
