rough start 530i
ok guys i didn't use my car for 2days and now when i started her up the whole car was shaking after awhile everything was running smooth. maybe rough idle? but it wasnt cold. has this ever happen to anyone? and is it normal? thanks.
Originally Posted by jet190rs' post='493600' date='Nov 13 2007, 12:59 AM
happens to me only when left outside in the cold.
was it cold overnight?
it was not cold at 620 pm. dose dat mean i have to heat up the car every single day to keep it running smooth?
Originally Posted by Black BMW530iA' post='493616' date='Nov 13 2007, 02:40 AM
What type of oil do you use? When was the last time you changed it?
My Ride: F11 -14
But I had similar problems with my 330i -03 (same engine as in the first years 530i's) where the engine seemed to be running only on 5 cyls. Irang my local BMW dealer and they said that it's a known problem without any real remedy - I should switch the engine off and start again. I did, and the problem was over. It happend especially if I started the egine cold, switched it off again after a couple of seconds and then started it again. (eg moving the car for washing in front of the house)
Originally Posted by narvselius' post='493654' date='Nov 13 2007, 05:12 AM
You haven't specified what year your 530i was built, nore where in the world you live, so it isn't that easy to help you...
md750i
04-08-2015 06:08 AM
