Replacing black rubber trim around windsheild
Old Mar 12, 2010 | 01:16 PM
yajimbo's Avatar
My Ride: 2004 BMW 530i | Sport Package | Auburn Interior | Silver Grey Metallic Exterior
Hello all
I was wondering if replacing the rubber black trim around the back window and windshield is something that has to be done by a professional or if this is a DIY moment. The trim is coming apart looks like crap too.
Thanks
Old Mar 12, 2010 | 02:22 PM
EV4530's Avatar
Click Me
I ordered my trim last night.
Order trim here
Old Mar 12, 2010 | 06:56 PM
No Onions's Avatar
My Ride: '05 545 Jet Black, Miro 111's, Painted Calipers, Slotted and Drilled Rotors, Ultimate Interior LED Kit, ACS Rear Spoilers (reps), HID 7k Fogs, Black Roundels and Badges, 20% Tint, Mtech V2 Angel Eyes, Ksport Coilovers, M5 Bumpers and Side Skits, ACS Front Lip (rep), and probably more on the way as you read this...
i was told with the back window that there's a chance of it cracking. it was worth it for me to shell out the $240 to have it done by a professional (think dealership wanted $300).
Old Mar 12, 2010 | 08:33 PM
akgolfpro's Avatar
My Ride: 04 530i
The rear on my car was a piece of cake! took 25 min, just make sure you start at the bottom and work your way arround! dont use pressure on the glass to pry, push the metal sleeve away from the glass where it has already been separated. I couldn't get the front removed, just had them replace the glass under comprihensive through insurance and gave them the OEM top seal to install! Most glass companies use a universal molding for the front!
Old Mar 12, 2010 | 08:39 PM
akgolfpro's Avatar
My Ride: 04 530i
If you want to see how easy it is to remove, open the trunk and start at the bottom with a flat head screwdriver, med. size and push it away from the glass! after that just slide the screwdriver in the slot where the glass was and push it away! Just take your time and work it all the way arround!
Old Mar 12, 2010 | 09:22 PM
ivan545's Avatar
I just had my rear windshield molding replaced its very easy. Remember to spray some soap and water so you can slide it in easy.
Old Mar 13, 2010 | 01:07 AM
lilazngrl4o8's Avatar
My Ride: 04 545i Jet Blk, Blk Int, SMG, Sport, Nav, Prem, CW Pack, L7, PDC
Awesome. Need to replace my rear window trim too. I did the front and it was such a pita to slide the rubber piece in. Didn't attempt the rear window trim the same day cause I was dreading that it would take as long as the front.
srogers535x
14
Apr 26, 2015 09:39 AM
TroyE60
Apr 14, 2015 06:30 PM
skrelnik
Mar 25, 2015 10:50 AM
Guest_skier566
Apr 7, 2004 12:54 PM
