Removing wire harness around intake manifold on 545
I'm in the process of taking off intake manifold of my 545i and I started with wiring harness that is mounted to it. I got all cables disconnected, but I can't figure out one. Its on passenger side right by the heat curtain. It's a 1/2" thick conduit with bunch of wires inside that goes straight down behind the engine. Anyone knows where does it go or where to unplug it ?
Also if you are just removing the intake you don't need to remove the trans harness. If everything else is disconnected, use 2 small bungees and tie the 2 junction boxes up vertical to the wiper arms. This will give enough room to work around.
thesalboy
04-08-2015 09:13 AM
