regular gasoline
Old Mar 7, 2011 | 10:26 AM
  #61
mookish's Avatar
My Ride: 2008 550i SA M-Sport Package
Originally Posted by tuffluck
i mean really, what are you arguing is cheap? we have proof right here and right now that bmw says 87 octane is acceptable right along with 93 octane. and on top of that, i happen to get better mpg (on 93 i got 28 as a best in 9 months, don't tell me 33 is a fluke, controlled or not). combine those two pieces of information, and that says to me using 87 is not being cheap, that's being smart (in my situation). so basically, you're saying one is being cheap for not doing anything wrong, but saving money. what a profound statement.
the reality is that bmw has both said use 93 and use 87, so why are you only believing 93 is what they really meant? because they advertise it more, because your owner's manual from 2007 says 93 even though someone else's owner's manual from 2009 says 87 is okay? it's just illogical for you, or vern, or anyone to condemn other people because you cannot push past your fear of disobeying corporate advertisement.
this sounds a lot like a religious argument, no offense. one person says this isn't true and we have some proof, the other person says we don't believe your proof, we have more proof and faith that bmw was right when they said 93.
Yes 87 is "acceptable" just as is riding on your donut spare. But it is not recommended. I don't believe any corporate advertising. I believe in the facts and it has nothing to do with BMW, any high performance engine will do better with higher octane gas. When I had a Honda Accord, I used regular. I will not use regular in the 550. "Regular octane is recommended for most cars. However, some cars with high compression engines, like sports cars and certain luxury cars, need mid-grade or premium gasoline to prevent knock."
So again, do what works for you. Or publish a controlled study that is accepted by the EPA and I'll roll with you.
Old Mar 7, 2011 | 10:47 AM
  #62
MRV99's Avatar
well you guys can "do your research" all you want, but here is some real-world data for you to chew:
i filled up with 87 at valero on my highway drive back home. i went 150 miles and got 33mpg (idrive and actual--filled up again when i got home to confirm idrive). my previous best highway was 28mpg on 93, in fact on the way down there i was getting only 27.
gotta say, not only is 87 cheaper, but for me, this is a pretty obvious improvement. i get significantly better gas mileage. 5mpg+ more is astonishing.
gonna be sticking with 87 i believe.
I have a question about your 87 gas, Does it contain any ethanol? Does valero use ethanol to increase the octane rating of the higher level gases. I ask this simpley because ethanol does increase octane but does reduce the energy contained in the fuel. If your station has 87 without ethanol and the 89/9x does contain ethanol, that would be the reason for your increased mileage. I have filled up at gas stations near heavy boating areas which has pumps which specifically state there is no ethanol and is directed tward people with boats. Ethanol absorbs water and most boaters that I know make sure they get non-ethanol gas. Every time I use 100% Dino fuel, my mpg jumps a bunch.
Old Mar 7, 2011 | 11:14 AM
  #63
tuffluck's Avatar
so what part of "this has no effect on the engine life" do you find incorrect and/or unproven?
10% ethanol.
Old Mar 7, 2011 | 01:40 PM
  #64
vern's Avatar
My Ride: 2001 BMW330ci, Steel Gray, Black leather, Steptronic, PP, SP, PDC, Heated seats, Xenon head lights, HK, 6 disk changer, OEM alarm, OEM clears,Iice white fog lights ,Universal trasnciver, 17 inch Michelin Pilot Sport Tires 2005 530i Titanium Gray,Black leather, Nav.,HUD,PP,CWP,SP,PDC,Xenon lights,Steptronic,Logic 7 sound system,,Fold down read seats,Power shades ON ORDER
vern, if i got a nickel for every worthless post you posted in this thread, i'd have enough money to switch back to 93 octane for a year.
The only thing that proves to me, and probably others is how cheap you really are and the BS in your posts.
cheers
vern
Old Mar 7, 2011 | 02:41 PM
  #65
SFS550's Avatar
From: Santa Fe Springs (SFS) - L.A. (SoCal) USA, North America, EARTH
Originally Posted by luigi524td
IF you insist on doing that I recommend you use only Tier 1 regular gasoline. That said, I would not use regular grade gasoline, on a regular basis, in any BMW that recommends Premium gasoline. IF you are doing it to save money, drive fewer miles or drive slower etc. instead.
It does tickle me why anyone (I'm not saying that's the case for you) would spend $40K - $80K+++ for a car and then try to save at MOST $200-$300/a YEAR by buying regular vs premium gasoline.
I'm with Luigi on this one. I don't mind paying extra for 91 octane. If you're concerned about getting better mileage maybe this isn't the car for you. Perhaps consider a Toyota or Honda as your next vehicle.
Anyway, speaking of higher octane. How does everyone feel about 100 octane? I tried it a few months back at about $8 a gallon but didn't notice any difference.
Old Mar 7, 2011 | 03:39 PM
  #66
AchtungE60's Avatar
My Ride: E60 530i
People haven't commented because this is not a forum for cheapo's so most here just run the premium and be done with it, we knew what we got into when we bought the car. And plus you have no hard evidence that you're getting better mgg, except for your words. A drive back and fourth means nothing because if you REALLY want a controlled study, conditions and driving style have to be EXACT for both runs. Other than that, who knows. Everything else is just an estimate.
So do what works for you, just don't make it seem like you've debunked and exposed BMW and we're all being duped into using premium, BMW doesn't get kickbacks everytime we fill up.
This argument has been had many times before you and will continue until the end of time right along with the which oil is better threads and the like.
When I fill up on 89 my digital cluster tells me that i have more miles available per full tank than on 93.
lol
Do you think EPA is not controlled by corporations along with everything else?
OP - Once my old Economics professor did explain the theory of gasoline and the octane ratings and also about the corporate hand in it and also the entities establishing the rules that govern it. I don't remember everything but i can tell you that much of the world is fooled. I personally have never used 87. The lowest we have in my area is 89 and I run that like once in every three tanks just to check it out. When I had my old E46 323i (which was a 325 renamed for BMW's advertising purposes....had the M52TU 2.5K engine) I used 89 after I noticed increase MPG and performance with the 89 Octane. It was also easier on my pocketbook.
I personally use 91 and 93 exclusively now because I do care about the car and the next owner to be quite honest. I've already given it tender care so might as well finish it off until it's no longer my vehicle. Really the car is metal, glass, plastic and rubber so who gives a shit? But I'd like to keep any issues down because I would like to retain my resale value. Fact is most of these people are brainwashed. I'm not one of them but when you're selling to a brainwashed person you have to understand them and find their angle. Personally I'm trying to let go of a lot of things that are material in nature.
So like I said before (I think I said) if you want to run 87 or 89 go right ahead, I don't think it really matters. For me, i don't care enough to educated myself in something that is never ending and very 'worldly' ....after all it involves primarily money right? How much money can I actually save in a lifetime? Or rather in this car's lifetime? Not much so personally I don't really care. I'd rather educate myself in things that will matter to me in life. And if i can get ahold of a late 80's pickup bare-bones this definitely will not help me. I have to agree with most of what you said especially after seeing the documentation around it....keeping in mind the facts about corporations etc.
Old Mar 7, 2011 | 04:28 PM
  #67
white535xi's Avatar
the only thing I use is 93, honestly how much can you be saving with 89. If you have the money to buy a BMW than money spent on gas shud;nt be an issue
Old Mar 7, 2011 | 05:21 PM
  #68
tuffluck's Avatar
i don't mean to be rude, but that truly is not the argument. i do well for myself and money is not a concern, however in the 9 months i've had the car it has been in the shop for more reasons than are expected from a bmw. i truly just don't like the car anymore and do believe is prone to problems; simultaneously, the research i have done shows 87 may cause knock, but even knock won't hurt the engine. since i have lost the respect for my bmw, i really don't care about knock. saving money off of an expense that has already gone wrong seems like the totally logical thing for me to do.
adding 5-6mpg is an added bonus. some of you guys that fail to read or just like to be judgmental really come of as morons.
Old Mar 7, 2011 | 05:55 PM
  #69
or_550i's Avatar
I did an experiment this week.
I did a lot of in town driving with a little long distance (~200 miles) of high speed freeway driving. I drove very spiritedly. I filled up with 93. Got 22 MPG.
Then on a long journey of high speed freeway driving (+200 miles) I filled up with 87. I drove like I used to with my old Prius: hypermiled as much as I could and eased on and off the gas. The only thing I noticed was a lack in get-up-and-go. I heard no knocking. My mileage for the trip (with 87) was 25 MPG.
RE: morons. The problem is that you've purchased a car that 90% of the folks here don't know how to/can't work on it. Their only answer is going to be "take it to X" which leaves a lot of room for opinions. There are other forums, like rv3 and pointedthree, where the focus is on older models and requires more *real* knowledge. Hang in there.
Old Mar 7, 2011 | 06:11 PM
  #70
AchtungE60's Avatar
My Ride: E60 530i
+1 well stated. Now let's move on.
