rattling caliper and squaking brake noise
My Ride: Sapphire Black 07 530i non-sport
7000k Angel Eyes
6000k HID Xenon adaptive turn Head lamps and Fogs, Clear LED Turn Signals front/back and side markers. Clear bright license plate lamp. Full interior lighting upgrade.
Coding: daytime angel eyes, auto windows up, and digital speedometer. (Thanks to John at Motorcepts.com)
OEM Tinted LCI Tail lights (Thanks to David at http://www.luxmotorwerks.com
Oem Mtec rear bumper with diffuser and M5trunk finisher
Debadged! The best paint work! (Thanks to Desimone BMW)
20x8.5 +18 20x10 +25 Concept One RS-8 Black Machined Chrome Lip
V6.1 cables (Thanks to Bruce Miranda)
Nitto Invo tires 285x30 R20 - 245x35 R20
Discounttire.com
Vac Motorsports ecu chip upgrade, and fender roll
http://vacmotorsports.com/
wish list:
Rieger Front bumper
Hamann side skirts
Custom quad exhaust
Rpi Ram air intake scoop
M5 SMG shift knob
KW Variant 3 suspension
Brembo Big Brake kit
LCI Heads
Tints
BMW M5
so i finished replacing my front rotors and pads. while test driving i noticed a rattling caliper sound in the left , and a squak grabbing sound right before each stop in the right.
i had to leave out the location screws in the rotors, cause i drilled them out and had no replacement, but I've seen cars where they are sometimes left out as well, so I don't think that would be the problem. ( twas a bitch to put on though)![Fcuk](https://5series.net/forums/images/smilies/imported/fcuk.gif)
I also polished the whole caliper to a shine with a grinder and dremel. i was going to paint them after but the silver looks preety sharp. but i hope i didnt grind too much away...
btw while doing this i noticed they are ATE calipers if anybody was wondering. had no idea they came stock that way.
before i rip everything apart to examine the problem, can anybody guess what i messed up this time?![Bashwall](https://5series.net/forums/images/smilies/imported/bashwall.gif)
oh the rotors were slotted drilled and coated, was told not to clean the rotors with brake fluid before bedding them. which i found rather odd.
My Ride: 545i
Engine: N62
Did you reinstall the rattle clips properly? I would definitely get the location screws installed as well. Is the a vibration in the wheel while braking? Did you put the anti-squeal paste on the back of the pads, and the contact points on the caliper where the pad sits? Did you clean off the contact points with a wire brush? Did you clean off the caliper guide pins?
7000k Angel Eyes
Discounttire.com
wish list:
Rieger Front bumper
Hamann side skirts
Custom quad exhaust
M5 SMG shift knob
LCI Heads
Tints
BMW M5
I did all that and more. One thing I noticed was the pins being very dry, even after lubing them with brake lube (silicon paste) a few days earlier. I got jammed cause of the seized location screw, so i put everything back together and went to the other side.
The pads did come with a silver paste, but I had silicon brake lube, so i used that on the back of the pads instead. is there a difference?
The location screws...One side I may have damaged the thread while drilling, so putting a location screw may not work.
I guess I must tear into it again.
![Crying](https://5series.net/forums/images/smilies/imported/crying.gif)
Guide pins do not get lubricated. They have to be smooth, no rust and the dust boot must be intact.
Rotors never get cleaned with brake fluid. I think you meant brake cleaner??
If you munged up a couple of threads or one side of the hole, the location bolt will still go back. Just clean up the threads with a wire brush and razor knife if you need to dig out anything.
I always use this brake lube on the rear of the pads and clips:
Permatex Ultra Disc Brake Caliper Lube (8 oz) 24110: You
srogers535x
08-05-2015 08:48 AM
PelicanParts.com
08-04-2015 01:34 PM
