bmw 530i (e60) hit a coon or fox
Old Apr 28, 2014 | 06:03 PM
undacovalova's Avatar
Default bmw 530i (e60) hit a coon or fox
I recently hit a racoon or fox on my way back from new york. I made it home safely, but noticed that my rad had moved back. On further inspection it seemed like the passenger radiator carrier mount has been bent as well. I'm trying to remove the mount and then bend the metal bracket and reinstall the plastic holder. The problem I'm having is that the plastic mount holder or whatever that holds the radiator carrier in place wont come loose. I don't know if i'm doing it wrong, but I know I have to press and the pull down. Does anyone have any tricks for this or able to give me a hand i'm out in oshawa.
Thanks
Randy
Old Apr 28, 2014 | 06:43 PM
milellie111's Avatar
My Ride: 2007 550i Sport
Your title had me worried for a bit
Old Apr 28, 2014 | 07:14 PM
twh's Avatar
twh
My Ride: 2006 BMW 530xi 6MT
Engine: N52
Thanks
Randy
Not sure what part you mean. Did you get the radiator fan out? The fan assembly is a little tricky to get out.
Old Apr 28, 2014 | 07:46 PM
Lower cooler bracket. Mounting parts F radiator. BMW # 17117542517, 17114715021
this is the part
Old Apr 30, 2014 | 06:56 AM
anyone?
Old Apr 30, 2014 | 11:11 AM
twh's Avatar
twh
Engine: N52
You got #3 out and you are looking on how to get #18 out??
Have you removed the under-body plastic panel and taken a look from below to see how it's in?
Looking at a #18 part photo, it looks like it has some molded in clips.
Old Apr 30, 2014 | 12:12 PM
it is a clip that you have to push in and pull it off a metal clip but i cant seem to do it. I dont know if there is a special technique
Tsoup
15
Dec 20, 2021 11:14 AM
turbogate
Apr 11, 2015 05:02 PM
joeekrub
Mar 25, 2015 07:00 AM
BYS2
Mar 24, 2015 03:13 AM
Mihainede85
Mar 11, 2015 09:45 PM
