Question about Active Steering
Old Oct 13, 2004 | 02:30 PM
heezy545i's Avatar
Okay so at speeds less than 45mph, there is a 44 percent quicker steering ratio. At speeds above 75, active steering provides an 11 percent slower steering ratio.
What about for speeds between 45 and 75? What type of ratio do we have at those speeds?
Old Oct 13, 2004 | 03:21 PM
sg530's Avatar
The rate of ratio change is a smooth curve that bends the those speeds and is a straight line between them. Somewhere in this forum I recall the post showing the technical description with the graph.
Old Oct 13, 2004 | 05:30 PM
realtyman's Avatar
My Ride: Now Driving a Freakin' Prius! Was... 2004 545i | SMG | White/Black | Sport | NAV | Logic 7 | PDC | Fold-down Seats | Adaptive Headlights | Cold Weather Pkg | Clear-again Bra | Mud Flaps | Bluetooth | Coat Hangar | Aux Input | All Weather Mats | 18"X8.5" BBS RK w/ Michelin Pilot Alpin's (winter) | New steering rack @ 1.2K & 17K miles| Software V.19.1 | B&B Exhaust (vrrrroooooommm!) <---Click.
Another benefit (if you will) of Active Steering is that it will help correct an oversteer condition.
Oddly enough, it works very intuitively and you still have a feeling of being in control and not that the car is driving you... or so I've heard.
Old Oct 13, 2004 | 06:06 PM
Jimbo's Avatar
It's almost too sensitive. Is there a way to adjust the ratio?
Old Oct 13, 2004 | 07:09 PM
yogibear458's Avatar
My Ride: 04 545A Dynamic Drive Pkg (Active Steering; Active Stabilization) Sport Pkg, Premium Sound, CD Changer, Rain sensor wipers, Red Rear reflectors
I like active steering except when I'm backing in to my garage. Now I have to line up and back straight in whereas before i could be sloppy and made minor steering corrections as I backed in. With active steering I tend to over-correct when backing in.
I also wish there is a way to turn it off.
[snapback]44548[/snapback]
Old Oct 13, 2004 | 10:44 PM
Jimbo's Avatar
^^^^Sometimes parking in a tight spot would be easier also.
Old Oct 14, 2004 | 02:43 AM
Flowerfred's Avatar
Active steering is a blessing. After a while it does become intuitive. You can pretty much predict the ratio from the speed you're going.
You only notice it if you try parking a car without as.. I nearly crashed my wife's car cause I wasn't steering enough.
Old Oct 14, 2004 | 03:03 AM
quite true... I only have 1600km on my 545i .. I guess I'll get used to AS as I log more hours/km behind the wheel.
You only notice it if you try parking a car without as.. I nearly crashed my wife's car cause I wasn't steering enough.?
[snapback]44654[/snapback]
jfmartin25
Nov 2, 2022 01:42 AM
shervinj
May 8, 2015 09:03 PM
TexaZ3
May 6, 2015 09:54 AM
das
Jun 2, 2003 03:55 PM
