Question
Old Sep 10, 2007 | 10:21 AM
khooger's Avatar
How did you guys set up the 167's or 166's on your cars? I have a 545 and the dealer says it will not fit and I would have to get 8.5 x 19 all around and not the staggered set-up?
Old Sep 10, 2007 | 10:50 AM
BMWSTL's Avatar
My Ride: 2008 550i ZSP with Style 167 wheels
That's BS. Your dealer is wrong!
I have 167's (staggered) and moved the 245's and 275's from the stock 172 wheels to the 167's. Works great!
Lou
Old Sep 10, 2007 | 10:54 AM
monacobmw's Avatar
Yes, your dealer is wrong.
Send the dealer to this site to learn about the car that he services.
Old Sep 10, 2007 | 10:56 AM
KEBABLAND_BMW's Avatar
My Ride: BMW E60 530i & E39 540i (wifes car) AWAITING NEW 535d
dealers wrong, even i know that
Old Sep 10, 2007 | 11:05 AM
khooger's Avatar
Do I need spacers on the back?
Old Sep 10, 2007 | 11:11 AM
EBMCS03's Avatar
Only if you want to for the rear. spacers only make it stick out more so it would be "worse" in the same sense as what your dealer is trying to tell you.
The stock OEM rear wheel and tire combo from the M5 will work fine for the normal E60 its the front that needs to be 10mm narrower for it not to rub. so use 245s in the front instead of 255s that come stock on the M5/M6 wheels. For better matching rolling diameter use 275s in the rear but 285s will work fine.
Old Sep 10, 2007 | 11:13 AM
E60BEEMER's Avatar
Cool
me too
Old Sep 10, 2007 | 11:23 AM
khooger's Avatar
So with 8.5 x19= 245/35/19 and 9.5 x19=275/30/19......right.....should be ok?
Thanks for the help.
Old Sep 11, 2007 | 06:17 AM
olli_535d's Avatar
My Ride: 535d Sport, carbon black, media pack, visibility pack, grey leather, heated seats, sun protection glass, voice control, Eibach ProKit, 19" 166 style wheels, e-maps ECU remap to 325hp and 640NM, top speed limiter removed
Dealer would only have a point if it was an E61 touring, as the wider rears with the 32 offset (e.g. style 172 wheels)catch on the inner wheel arch. But even on the touring the use of spacers will correct that.
On the E60 the 166's or 167's are ET28 on the rear and even take a 10mm spacer and will not catch, even without arch rolling, using a 275/30/19
iNDOLiFE
Bluetooth & Cell Phone Forum
Aug 4, 2015 07:06 PM
e60_simr
Jul 29, 2015 02:35 PM
aqualibrium
Jul 21, 2015 03:11 AM
w84me
Jul 10, 2015 10:56 AM
ST JAMES
Jul 3, 2015 07:04 PM
