Putting my 550 on a Dyno tomorrow
Old Jul 15, 2006 | 11:14 AM
tachyon's Avatar
Originally Posted by TCAOS' post='311150' date='Jul 15 2006, 02:02 PM
I am not happy the car only put out 369Hp.
Actually, that doesn't sound too bad. Is that 369 Hp at the rear wheels? If so, you have a rocket.
Old Jul 15, 2006 | 11:17 AM
EBMCS03's Avatar
Hey we posted the same time 12:14 about WHP or Crank HP...
Old Jul 15, 2006 | 11:20 AM
znod's Avatar
Originally Posted by EuroCarFan' post='310532' date='Jul 13 2006, 11:57 PM
Wish I did a baseline run for my car too. Just found out there's a dyno place near my house so I'll try to get it done before I get the next Dinan performance mod.
Old Jul 15, 2006 | 11:26 AM
znod's Avatar
Originally Posted by EBMCS03' post='311161' date='Jul 15 2006, 02:14 PM
So you got a gain of 9hp? You're talking about Crank HP right not WHP... if its WHP OMG THATS SOOOO GOOD!
I am sure he is comparing 369 to 360 or else he would not be disappointed. I am eager to see how it turns out. The B&B should do essentially an unmeasureable amount. I am not sure about the homemade CAI. Making a properly functioning CAI is tricky business--not like just putting some pipes on that give cold air--design is very important--not meaning to imply that he and his friend don't know what they are doing in designing a CAI. I think that it is even possible that his "chip tuning" is compensating for a loss because of the CAI. I wish he had his stock intake on at this point.
Old Jul 15, 2006 | 12:25 PM
my530i's Avatar
OK, the issue is not clear yet. What is pre-tune WHP for 550i? That needs to be answer, and I guess it should be ~320 hp at the rear. I want to know, too.
Old Jul 15, 2006 | 01:07 PM
znod's Avatar
Allowing for all parasitic losses, I would estimate RWHP using the simplistic .8 X 360 = 288 or .825 X 360 = 297 for the 550i For some HP info, go to posts 124 and 125 of this thread.
Old Jul 15, 2006 | 02:14 PM
EuroCarFan's Avatar
My Ride: E60 M5, F85 X5M
Yeah, parasitic losses through the drivetrain will take about 20% of the crank HP away so I'm sure he means he got 369 crank HP, not WHP. If he got 369 WHP that means he gained about 100 horses from a chip upgrade.....WOW, that would be awesome!!
TCAOS, price-wise, I would consider 9 HP pretty good since I know Upsolute only charges about $400 for the programming. Most exhausts won't give you that much gain and will cost double or tripple. On the flip side, when I talked to them last, they said the average gain would be around 18-20 HP for a 545 but it would depend on the car. Let us know if they're able to improve on the numbers...good luck!
Old Jul 15, 2006 | 02:31 PM
my530i's Avatar
9HP over 3800lb car does make any difference since to get that 9hp, you need to rev a little higher. Increase by at least 30hp would make sense to do. Just my $0.02
Old Jul 18, 2006 | 06:46 AM
TCAOS's Avatar
Sorry for the delay. The Dyno run was crank not rear wheel. The cold air intake was not put on due to the mixture being off. I feel that 9hp is not a good gain, I feel it gained the extra HP from the B&B and a K&N filter I have in the stock box. Upsolute at the least calls for a 15 - 20 HP increase. The decrease of HP through the drive (SMG) was 20%.
Old Jul 18, 2006 | 10:27 AM
Bimmer32's Avatar
I think the commonly accepted rule is 82.5% for autos and 86.5% for manual and auto with converter locked up. I don't think 9hp makes much significant performance difference for 300+ HP engines with cars weighing in 3800+ lbs.
srogers535x
Aug 5, 2015 08:48 AM
rkilpa
Aug 4, 2015 06:14 PM
rice_rocket88
Jul 23, 2015 04:13 AM
Euronuts
Jul 21, 2015 04:36 PM
ripley
DIY: Do It Yourself
Jul 12, 2015 01:49 PM
