Probably easy questions
Old Jul 1, 2011 | 01:29 PM
Jaxbeachbmw's Avatar
I have two questions that are most likely easy for all of you, but I could not find anything via search results:
1. Prior to this car, I had a CTS. I could program the climate control to NOT turn on when I start the car. Can I do that in a 2006 E60?
2. I have never used a fuel such as Gumout, but love this car...is this something I should do?
Thanks in advance,
Old Jul 1, 2011 | 01:32 PM
pjinca's Avatar
Thanks in advance,
1) Yes, you can turn the fan speed knob all the way down and it will no longer come on automatically
2) I use Chevron with Techron fuel system cleaner about every 6k miles, usually about the same time as my oil changes.
Old Jul 1, 2011 | 01:34 PM
rctmthouse's Avatar
not sure about #1 since I still have the problem of it turning on intermittently but as for #2, I assume you're referring to Gumout fuel injector cleaner, just use the Chevron with Techron fuel injector cleaner. Supposedly it's the same thing that BMW sells with a different badge. I use one bottle every month since it's pretty cheap at Autozone or Costco.
Old Jul 1, 2011 | 01:51 PM
Thanks for the tips on the Techron.
As for the fan, I can turn the knob all the way down but it still turns on with the ignition, it just turns on at a lower speed.
Old Jul 1, 2011 | 01:55 PM
rctmthouse's Avatar
I usually just press the power button if it turns on. That's the easiest way or someone else just suggested in another thread, move it to the middle and it will not turn on and off intermittently.
Old Jul 1, 2011 | 04:03 PM
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
This is actually incorrect. This setting has to be coded.
Old Jul 1, 2011 | 08:18 PM
Yes! That's what I thought. So how do I do it?
Old Jul 1, 2011 | 09:21 PM
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Do you have the cable and software?
That would be the place to start.
star69me
Jun 17, 2015 07:40 PM
windnsea
May 25, 2015 09:49 PM
jcolley
Mar 17, 2015 09:15 AM
brian1225
Apr 16, 2004 05:59 AM
Beemer
Jul 9, 2003 05:38 PM
