Please Note Pre LCI to LCI Retrofitters
Old 11-07-2010, 12:25 PM
d4rkchocolate's Avatar
If your going to retrofit your Pre LCI to LCI,
Make sure you get all the parts first, Especially the LCM (light control Module).
if you dont, this will happen
because i already wired my lights from 8 pin to 12pin, i already had parking light errors, and spoke to greeeeeeeeeat people here, and was reccommended to get the New updated LCM because mine was under 2006.
back in the UK, i drove in thge countryside, and it was sooooooo dark i had to use my High beams (the flashers) and the next day i saw it melted my reflectors, I'M VEEEEEEX
i now realise that if u dont have the correct lcm, the car will give a very high output (heat) and the new LCM gives out slightly less output so i doesnt melt the rings....
so looks like i have to buy another set of LCI;s unless i can fix these...
im so upset
Old 11-07-2010, 12:38 PM
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Larger pic? Can't see it very well.
Old 11-07-2010, 01:35 PM
jas_r_1's Avatar
My Ride: 2006 520d - 19" 172s- Remapped - LCI taillights V6 cables - LCI xenon headlights - Denison 500 with BTA1500 - led interior lights - OEM led number plate lights Planned mods: Folding mirrors - Modmynav kit - High gloss shadowline trim -
What a b!tch
So your definately going down the new LCM route then?
I'll still drop those resistors round (hopefully tomorrow work permitting).
Old 11-07-2010, 02:36 PM
BlaSTiWi's Avatar
Which reflector? The big main beam or the smaller one?
Old 11-07-2010, 02:39 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
see how his high beam looks cloudy.
is that high beam lamp used normally? i thought in the US at least that it does nothing on lci cars.
Old 11-07-2010, 02:44 PM
Dav530d's Avatar
I've done exactly the same to mine. I just live with it. Try not to leave the high beam on too long
Old 11-07-2010, 02:46 PM
turboawd's Avatar
i wonder if the pre-lci cars have this potential issue, cause i hold my high beams on once in a while.
Old 11-07-2010, 03:33 PM
B6S4's Avatar
My Ride: '04 530i 6MT '04 Audi S4 6MT
What swap did you do originaly? Pre-LCI Halogen->LCI Halogen? Pre-LCI xenon->LCI Xenon? If you did Pre-LCI halogen to LCI halogen, the LCM shouldn't have an effect on the high beam as both lights use a 55w H7 bulb. The only time the LCM would have an issue with power is if you did Pre-LCI to LCI Xenon. The LCI Xenon uses a 35w high beam bulb vs all other lights use a 55w high beam bulb. Are you sure you have the correct bulb in the high beam?
Old 11-07-2010, 03:57 PM
BlaSTiWi's Avatar
high beam? It's a Bi-Xenon so the hi-beam is in the main beam ... You mean the smaller reflector ...
If it has a frosted lens it suppose to be for a cornering light ... not for high beam.
I think member BenAnd already warned those who's doing conversion to not use that light for too long.
Old 11-07-2010, 06:13 PM
turboawd's Avatar
i guess i should have said "inner lamp" or "flash to pass lamp", which i use as a high beam sometimes by holding the turn indicator.
Quick Reply: Please Note Pre LCI to LCI Retrofitters
