Pathway Lightning
Old May 3, 2004 | 09:16 AM
mlist84's Avatar
hi guys, im really stucked in this "pathway lightning" matter. on the i drive menu under "lightning" ; i've set the time to 20s. but i got nothing soon after i turned off the engine and locked my car. there is no pathway lightning..i wonder how it works?
any of you try this?
Old May 3, 2004 | 09:23 AM
kiran's Avatar
Post
After removing the key press the headlight flasher. that will leave the lights on for the set time.
Cheers,
Kiran.
Old May 3, 2004 | 09:27 AM
mlist84's Avatar
OMGl.. so i need to push in order to be able to have that. i thought i just need to press the lock button or just remove my keys and the light is goes on like the other car such as mercedes benz...its weird.
thanks though.
Old May 3, 2004 | 12:08 PM
cidair's Avatar
My pathway lighting works as soon as I lock the car with the remote!
Old May 3, 2004 | 12:13 PM
pbarch1's Avatar
I had the same problem after my software update. I think that I pushed the overhead lighting buttons until they were in the correct position and all of a sudden the pathway lighting started working again. give it a try
Old May 3, 2004 | 01:24 PM
BMW530's Avatar
The "Follow Me Home" function i.e. pathway lighting is activated via the headlight flasher as mentioned after the engine has been turned off. This was the same as on my E46 320iSE and 325iSE. I was not aware of the remote activating this "follow me home" function. The remote will only activate the interior lighting as far as I know.
Old May 3, 2004 | 02:44 PM
sj3's Avatar
sj3
For US customers, does the headlight switch need to be in the 'A' position, or is it off, and pathway lighting works?
Thanks,
Sam
Old May 3, 2004 | 03:21 PM
JohanDC's Avatar
If you want to have it activated automatically when you turn your car off, and this is currently not working, then pay your dealer a visit because this function needs to be activated in car memory too (=hookup to dealer computer & change the appropriate car memory setting).
Georgieb
178
Feb 24, 2020 02:07 PM
Gizzler
Feb 17, 2012 11:25 PM
noonehome
Lounge
14
Jul 8, 2008 10:51 PM
sstudham
Feb 10, 2007 01:10 PM
yogibear458
Oct 7, 2004 04:22 PM
