Passenger side heat.
My Ride: 2004 e60 530i
What makes the heat work on the pass side? Heater control valve? Is it on or 2 valves and where at? Is there a blend door from hot 2 cold? Where is that located also? Luke warm heat on driver side and cold on pass. Please help.
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
First is your issue not getting the heat to blow hot since you say your driver side blows luke warm. It the heat is not getting hot then you need to address that first. When you post please list the year, model and mileage that helps us know what we are dealing with.
psam550
05-21-2016 05:56 AM
Lotus99
12-01-2015 06:35 PM
