Passenger Restraint System Error - Airbag Control Module? Plz help
#21
You know that's funny. I got mine from the same seller initially. MANY years ago. But then i needed updated cable and so forth to work with my 2000 E39 as well as a friend's 09 E90. And I couldn't find that seller. I looked at my feedback for dates and found that it was changed to EUAUTOHAUS. So I contact that seller and he informed me that they just started on ebay and used an old ID. So I bought the other kit. I'm happy because programming things myself made it so much easier on the wallet. Now I never have to spend a dime.
OP - If you're still having this trouble clear the codes, see if they come back. If they don't then no big deal. IF they do ask yourself the following:
When did this start?
What changed?
Is it intermittent?
What are the codes?
These will help you chase down the reason quickly because it's simply restraint system. It's tied only to two modules. You can either fix the physical issue or you can logically code the errors out. Coding the errors out just means it will not show the error. By default they will still deploy because there is redundancy.
What changed?
Is it intermittent?
What are the codes?
Hey AchtungE60 would you happen to know what the 93b4 error is? My car has been giving me different error codes. Went form93c3, to 93a8, to now 93b4.
Thank you
#27
#28
They did my passenger mat sensor awhile back, and i called earlier and the SA told me it was addressed before and told me he has to charge me to diagnose it FML. I dunno if i will try a different stealership here in socal.
