Passenger Resraint System malfunction
#31
My Ride: 2007 530xi Titanium
#32
Hey guys great news for all of you having that seat belt problem my 06 530xi passenger restraint light came on the other day i thought it was cause my girlfriend put a baby seat in the car the wrong way and it was just tripping well nevertheless after she got out and the baby got out the code was still there i was like really bmw wtf so i researched a little more and come to find out BMW HAS A RECALL ABOUT THIS PARTICULAR issue with the sensor in the 5 series in the passenger seat everything is covered in this recall for it 500 dollar fix with a free loaner better take up on it and its good till 2015 call your dealer and set it up good luck
#33
My Ride: 545i
Not so fast... As stated in other threads, it depends on other factors. VIN and the actual defect. The Error Msg can be caused by many different components and only the mat under certain VIN's are covered... Ok, if anyone has this warning, of course they should go and have it checked out as it is a safety item, but it does not mean for sure that it will be covered under a recall at no charge to the customer.
EDIT: I see this was mentioned already.
#34
My Ride: 530i base model
Are mat sensors only on front seats? because I have this warning also, it started after I dropped my backpack on the rear seat.
#36
My Ride: Orient blue '05 545i, Sport/Premium Pkg, 6Speed MT, Xenon, Navi, Blue2th, PDC,
Hi, Old post but I am having the same fault and were about to order the SBK until I read about your upgrade to SBK2.
First I presume that you haven't any faults since?
Could you explain what the difference are between the SBK and SBK2? The repair cable are because of a different connector or?
I would off course like the best (upgraded) version if it do sent gives problems in my 2004?
Br Mop
Br Mop
Hi,
It is already over a year since the repair and the fault didn't come back.
New\improved SBK2 cable has a little bit different design and it is using a different connector (plug) for the Airbag system.
Just google the part number and look for the pictures of the SBK2 cable and compare it with the old model in your car. It is really easy to see the difference.
This should be a good reference point
http://www.ecstuning.com/Search/Site...9780/ES163246/
