Overheating dilemma!!!
My Ride: 2006 530i
![Angry](https://5series.net/forums/images/icons/icon8.gif)
Hi i was wondering if someone could help me, I got an "engine is hot, drive moderately" message on my Idrive and then that was followed by "engine is overheated! stop driving" after checking i discovered a crack in my expansion tank so i replaced it and added some coolant but i'm still getting these messages, I also checked the coolant temperature sensor and the O ring is fine, there isn't any oil leaking into the spark plugs so the gasket is fine too. I'm suspecting the water pump but i'm not even sure where that's located. Can someone please help me?
My Ride: 2006 530xi w m5 tech kit, 2007 Mercedes e63 AMG, 2005 ford expedition
Sound like either thermostat or waterpump. 9 out of 10 is ure pump. Mine just went last week. Got same message Waterpump is on the passenger side. On the bottom
My Ride: 2006 530i
I tried the bleeding process ( car in idle, heat on low and step on accelerator for 10 secs) but nothing happened? and i do have a 6 Cylinder ( 2006 530i) So you think it's the water pump?
My Ride: 2006 530i
I'm starting to think it's the same thing, how much did u get your water pump for? I'm gna try replacing that and if that fails i'll probably have to send it to the dealership.
