OMG is it finished?
Old 03-07-2019, 10:14 AM
audiophool's Avatar
My Ride: 535xi
In addition to checking the heater solenoids, you can feel the temperature for the hoses attached to the valve assembly. Are they all cold? Have you checked for an electric auxiliary pump?
An option for airlocked cooling systems is to vacuum bleed with the engine running cold. I'm not talking about 20", just a little vacuum.
Old 03-13-2019, 12:47 AM
E60Japanese's Avatar
My Ride: E60 2006 sedan auto
Well more drama lololol
So I bought a new heater solenoids and put it in and of course I though I would be able to warm my old Bones but still no good
So it seems it must be an electrical problem
Maybe a heater. Relay?
I see there is one under the hood on the passenger side in the sealed electrical box
I checked all the fuses and they are okay
The other way is just to bypass the electrical and put a positive line directly to the switch to see what happens
But I would like to find the problem
Old 03-13-2019, 06:10 AM
audiophool's Avatar
My Ride: 535xi
IIRC, the solenoid valves are open when no power is applied, and they work by closing the valves (pulsing) to restrict flow to the core. If this is correct, unplugging the solenoid should simulate full heat.
Old 03-13-2019, 11:31 AM
jtbgonesailing's Avatar
My Ride: e60 530i e21 320i
Model Year: 2005 1981
Engine: M54 M10
When you replaced the heater valve, did you check to see if the valve was clear with no restrictions and open? Sounding more like you have a restriction in the heater cores, preventing the flow of coolant.
Review post #9 for flushing the heater core.
Old 03-13-2019, 02:49 PM
Well I'm not sure what happened yet but my heater started working
Last night I pulled apart the old solenoids and they were both seized and not operating
This morning I set off to work and no heat
40 minutes into the drive with blankets pulled over me to keep me warm the heater suddenly started working
So I'm not sure if it was electrical or water blockage so I will flush the core out this weekend to see what that looks like
The good news is it's working and I am thankful for everyone's help and advice
Old 03-13-2019, 05:50 PM
Engine: M54 M10
Great. The end result is what counts.
acuteperformance
33
06-04-2010 01:21 PM
P.S.B
11-28-2005 06:15 PM
darkside
23
11-28-2005 06:15 AM
Andy E61
05-22-2005 11:48 PM
rollee
Lounge
07-06-2004 10:41 AM
Quick Reply: OMG is it finished?
