Which oil for the engine ?
Originally Posted by Kuchar' post='455652' date='Aug 6 2007, 04:04 AM
Check out what Bavarian Machine Specialties here in Houston has to say about the 15k oil change:
Full Article Link
"I routinely see engines at 45,000 miles that have had two oil changes and are so gunked up that the engine will have serious problems with lifters, rings and bearings before the 60,000 mile mark."
![](http://www.bavarianmachine.com/images/photos/gunk_560.jpg)
"As a general rule, we recommend oil changes depending on each customer?s driving habits. Usually the mileage period for changes is 5000 to 7500 miles. We arrived at this range based on laboratory analysis of oil we drained from customer?s cars.
For comparison, the following picture is of an engine with 82k that we have serviced for its life time."
![](http://www.bavarianmachine.com/images/photos/no_gunk.jpg)
Full Article Link
![Help](https://5series.net/forums/images/smilies/imported/help.gif)
![Blink](https://5series.net/forums/images/smilies/imported/blink.gif)
Originally Posted by jordan23junkee' post='455627' date='Aug 6 2007, 02:45 AM
yes the bmw dealer uses Castrol full synthetic whuch runs about $12/quart and $5/quart at Autozone. Theyre both the same. Mobil 1 has 0w 30 for European engines fully synthetic which im going to give a try next oil change.
Does someone suggest to change the oil ?
I saw pics in this thread ..
Could in Audi change the oil or the car need something that only a BMW dealer has ?
My Ride: Mini Cooper
My Ride: 2005 530i, 1995 318ic
retired circa 1970 2002, , circa 1985 320, 1998 528i, 1998 740i
Originally Posted by cocy00' post='455651' date='Aug 5 2007, 09:03 PM
I say this due to personall experience. Had a E39 which I changed my oil according to schedule and after 3 years of driving it (abt 150k miles), the valve cover started leaking, so had a change of the gasket. When the mechanic took the valve cover off.... it was all yucky and gooey. when I reached the 165k miles mark had to have the head cleaned b'cos the carbon ond oil deposit had bloked all the lubricating holes. Had a E46 and changed oil every 7k miles and its still going strong (abt 200k miles and counting). Had a friend send me his E46 318i engine photos as per attached. Only done 100k km England and you can see the engine yourself. Mind you this was taken when the car was only 3-4years on the road.
Originally Posted by fjwagner' post='455751' date='Aug 6 2007, 05:29 AM
well, I am an engineer and deal with facts and your facts are certainly compelling. Thanks for spending the time to post those pictures. Those combined with my oil analysis will create a conservative approach for me. More conservative than the straight up analysis would suggest. I have a 318 with 152 k miles and it looks good still. However, those intervals have been closer to 7 k. An interval between I Drive recommended changes certainly does sound appropriate for the 530. Fred
![Devil](https://5series.net/forums/images/smilies/imported/devil.gif)
Originally Posted by cocy00' post='455753' date='Aug 6 2007, 05:55 AM
Well, I'm also intrigue with your findings.... but I have no doubt that the engine oil can still perform but that doesn't mean that they do not leave residues that will clogged the engine. Maybe BMW did not take into account the dirt which gets blown into the cylinder and also the carbon from combustion or maube they don't want your engines to last that long
Anyway, the goeey stuff does not show up in the oil when its being drained and also BMW engines runs much hotter than many other car maker's engine. It just makes you wonder if the oil filters are doing their job at all... ![Think](https://5series.net/forums/images/smilies/imported/think.gif)
I have been working on several people at the office that are still changing their oil at 3000 miles per Jiffy Lube's little sticker. Trying to convince them that is overkill with today's oil. I plan to keep my 530 for a long time. My 318 ic is at 152 k and counting. The oil indicator lights are typically around 7 k for that car which is more reasonable based upon your assessment.
mantraguy
03-09-2015 02:56 AM
