New CIP Version is out!!!!!!
Originally Posted by cobradav' post='467052' date='Sep 7 2007, 02:02 PM
Will not tell you anything if you can even use it now. Some have reported that the iDrive (not dash) hidden menu technique no longer works. However, I may be confusing true LCI vehicles with those updated with v26.xx.xx and higher. In any case those of us with nav cannot determin CIP (PROGMAN) level. Did you get any copies of your "reports" such as Measures Plan or Final Report. Those provide your old and new Target Data Status (TDS) which can be translated into a PROGMAN level (to some extent). Current TDS from 25.02.00 on is E60-07-03-525. I say to some extent as recently we have seen the TDS remain the same from 25.02.00 (back in May) through the most recent updates accomplished in August even though dealers have been stating v26.xx or even v27.xx. I believe this is due to the fact that no car functions have been changed. Only the way the dealer equipment handles PROGMAN or how it behaves DURING the update process.
Many that have had problems with recent updates might try going back in for re-programming as the quirks and outright errors in the upgrade process can leave gremlins in the many modules that are updated. That is why BMW (or their supplyer) are having to make these tweakes to the software even though no real fixes to the vehicles systems.
Originally Posted by FLBeamer' post='467204' date='Sep 7 2007, 11:27 PM
It says "reprogram and coded complete vehicle as per 84-20-06 refer to ksd for warranty" Does that make sense?
SI B 84 20 06
Phone, Navigation Systems September 2006
Technical Service
This Service Information bulletin supersedes S.I. B84 20 06 dated June 2006.
(New) designates changes to this revision
SUBJECT
CCC Navigation Stuck on "Accept" Screen
MODEL
E90, E91 (3 Series) with SA609 CCC Navigation
E60, E61 (5 Series) with SA609 CCC Navigation
E63, E64 (6 Series)
SITUATION
The customer states that sporadically, it is not possible to acknowledge the "Accept" button on the navigation system disclaimer screen using the controller.
CAUSE
Faulty Controller
CCC software
PROCEDURE
Fault currently present
Perform a short test on the vehicle and diagnose any CCC (Car Communication Computer) faults first.
The following steps are only valid if the Controller fault is currently present.
Select "Control Module functions" using DIS/GT1.
Select "CON Controller" from the control module list.
Select "Diagnosis requests" and "-Control knob".
Select "Pressure function" and "Display"
Press down on the Controller and the display should change from "not pressed" to "pressed".
If the status does not change or an error is displayed, replace the Controller.
If the status change is correct for the controller, perform a battery reset to regain functionality of the Controller. Do not replace any parts if the Controller is working properly. A future version of Progman will correct this fault.
Fault NOT currently present
(New) On a customer complaint basis only, update the complete vehicle per SI B09 05 01 (Coding, Individualization, Programming) Procedure B:
(New) E60, E61, E63, E64 use Progman V23.00.00 (Target Data Status E060-06-09-520) or higher.
(New) E90, E91 use Progman V22.02.00 (Target Data Status E089x-06-06-540) or higher.
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Defect Code Refer to KSD
Labor Operation: Refer to KSD
Labor Allowance: Refer to KSD
Vman33
Mar 14, 2022 04:43 AM
umnitza
Sep 2, 2015 11:28 AM
